video file at double speed
papat1
Post by papat1 »
I have captured a video file from my VHS recorder to my HD,but when I play it,it is not playing at normal speed. It is probably in fast forward speed,or close to it.How can I slow this video down.Thanks Papat1
htchien
operating_system: Mac
Post by htchien »
How do you capture the video file? And what DVD MovieFactory version do you use?
H.T.
Ted (H.T.)
papat1
Post by papat1 »
I capture it using ADS Tech DVD Xpress.Movie Factory is 3 SE. Thanks Papat1
htchien
Post by htchien »
Have you asked ADS Tech Support for updated driver?
Have you applied the update packs for DMF from http://www.ulead.com/dmf/dmf.htm ?
H.T.
Ted (H.T.)
papat1
Post by papat1 »
I have installed the update,but have not checked about an updated driver.This whole problem started when I had to capture a VHS tape using Movie Factory instead of Capwiz.There is a slight glitch in the tape,so Capwiz stopped at that point and wouldn't continue the capture. I found that Movie Factory would continue right through the glitch,but ended up with a fast replay as stated in my other post. I've also tried to edit out the glitch on this MPG file using Movie Factory,deleting the various frames, but have had no luck. Thanks H.T for your input.
