Using Movie Wizard I import 3.75 GB Mpeg 2 file and after I select
Create disk file size is calculated as 8.1 GB. The file was generated by Hauppauge WintTV USB2. I have seen problem like that
in some previous versions of DVD Movie Factory. By the way, the video editor shows correct file size, but as soon as I want to create a disk the size is recalculated to more than twice the size. I did not select neither background music, nor menus. Also, how do I go around the Themes, I do not want any themes. Is there any e-mail Technical support.
I sent 2 e-mails to Tech Support and received no answer.
Thanks.
V.
Incorrect File Size Calculation - Video Studio 10 Plus
Welcome to the forums,
This typically can occur when you go to the Burn module with your Project still in the timeline. Have you created a video file from your project, (share>Create Video File)? If you Project properties match that of your video, then it should smart render, rendering only the parts you have changed.
Now open a new project, and go straight to the Share>Create Disk (burn module). Do not place anything in the Editor's timeline. Once inside the burn module, insert your video files, build your menus, and continue on to burning a disk. Unless you have done something totally different, it should show the correct file size..
A Recommended Workflow has been developed to help guide you through the mine-field of video editing, as it pertains to Ulead's VideoStudio Programs. They can be viewed here:
Recommened WorkFlow for VideoStudio
You might want to read through From Camcorder to DVD tutorial.
