Lost my Windows Media Player audio after MF4 install
macwino
motherboard: Asus P45 - P5Q-E
processor: Intel E8600
ram: 8 GB
Video Card: BFG nVidia Radeon GTX 280 OC - 1GB
sound_card: on board audio
Hard_Drive_Capacity: 2.5 GB
Monitor/Display Make & Model: Asus 22 inch
Post by macwino »
Installation of MF4 causes Windows Media Player 10 to lose audio. When I play an mpg file with WMP there is no audio. These mpg files have AC-3 audio. There was audio before I installed MF4. I uninstalled MF4 and I again had my audio with WMP. I then reinstalled MF4 and I no longer had audio with WMP. Does anyone have any ideas about how to get my WMP audio back? And has anyone else experienced this problem?
Thanks, Robert
htchien
operating_system: Mac
Post by htchien »
I had the problem once, but solved it by removing Roxio Easy Media Creator 7 because Roxio audio codec seems to be conflicted with Ulead audio codec. Now I can play MPEG files with AC-3 without any problem in both WMP and Ulead.
Not knowing if your problem is the same, but might be similar.
H.T.
Ted (H.T.)
macwino
ram: 8 GB
Post by macwino »
H.T, I never had Roxio installed, but I have an Ahead Nero demo installed at one time but it's long been removed. I did a Registry search - for what it's worth - and deleted all references to Ahead. But it made no difference. Still no audio with WMP.
Thanks for the suggestion, anyway. Robert
maddrummer3301
Post by maddrummer3301 »
I'm going to find out on my machine tonight what's going on with that
and will post back.
Depending on the sound card you have I think it's in the
"Audition/Monitor Audio" part of Ulead's code.
On mine it stopped playing AC-3 and had muted one of the
ports on the soundcard mixer.
If your using a soundblaster card with the "What you hear" feature.
That is the WORST thing that creative ever did. Those cards cause
many headaches for programmers.
MD
macwino
ram: 8 GB
Post by macwino »
Hi MD,
Thanks for looking into this. There's also another sound anomaly that I'd thought I'd mention because maybe it's related.
If I import a video file from a DVD created by my DVR-DVD player, it has no audio when played in MF4. The file contains AC-3 audio. I am using the Import DVD-Video button under the Add Media heading and navigating to the video folder on the DVD in order to bring this video into the program. If I use the Edit DVD process instead of the Create Video DVD process, I retain the audio. So my files are losing their AC-3 audio when brought into the program the intended way.
I look forward to the results of your investigations.
Robert
macwino
ram: 8 GB
Post by macwino »
Am I alone in this, or is anyone else experiencing this problem?
Robert
Looey
Post by Looey »
I have the same problem of no dvd sound in WMP10 since installing MF4. The problem file is uldvdaudio and is located in program files\common files\ulead\systems\mpeg\. I renamed this file to uldvdaudio.old and now dvd sound works from Windows media player.
I haven't tested movie factory 4 yet to see what happens there. I don't know what the problems will be with that. This is a temporary fix for me.
I have Nero on my system that provided the dvd decoder before MF4.
macwino
ram: 8 GB
Post by macwino »
Looey, thanks for the tip. It worked - but not without its problems. By making this change I now have audio when I play an mpg file using WMP 10. However, I no longer have any audio when playing a file within MF4.
So it's apparently audio in one or the other, but not in both.
Robert
