Photo Explosion IPE.EXE Error
All about Image editing. Photography, Tips & Tricks, etc.....
Wild Child
Post by Wild Child »
Ok I had version 2 and encountered this error, went and bought version 3...same error, with no Modname to help with the error code etc., So I was stumped, called into the tech support and they were stumped also, because along with this error after uninstall I would get a demo shield error loading from the disk which furthered my confusion. So I started from that point, to see what software would conflict with the demoshield software, what I found was completely out in left field, but it resolved the problem and program now runs smooth as silk. The problem was with Quicktime 7. steps are listed below:
Uninstall program
Reboot system
Right click on start button go to and delete the nova developement folder
Reboot system
download crap cleaner, install and run it to get rid of the old registry files left behind.(do a google search for ccleaner)
If you have Quicktime 7.0 or higher installed go to add remove programs and uninstall it, Reboot system.
Now the installer from cd should run fine. after install I believe you will be asked to reboot, do so and run the program.
Hope this helps some folks.
WC
