All the questions below concern making a DVD, PAL in Ulead DVD MovieFactory 6.
1. When changing MPEG setting I can choose different frame types: frame-based, lower field first, upper field first.
I have captured and edited the video (DV-avi) with lower field first all the way. However, all the standard settings suggest frame-based. Is is a kind of DVD standard? Should I keep it or change it to lower field first?
2. Under the Compression tab I can choose either constant or variable data rate. Which one to prefer and why?
3. Which audio format to prefer MPEG Audio or Dolby Digital if I captured the audio in 16 bit with a standard DV camcorder?
4. In the Project settings I can choose the Field type between: No fields, Lower field first (DV) and Upper field first. How do these values correspond to the ones I choose under the MPEG settings as described in pos. 1 above? Which one I should choose and why?
5. As understand there is no way to delete objects in the templates of the menus. Why? It is very irritating. As I see it there is no way to start with a blank menu either. Nor to make these flying buttons stop. Etc, etc... Very frustrating and limiting if you ask me. However, it might be not the right thread to talk about. Sorry for that in this case.
I hope that you can help me at least with the first four questions above. Thank you.
