Splitting lines in Banner Text
GIF Animator, SmartSaver Pro, Plugins, Applets....
km
Post by km »
Probably another one of those 'bleedin obvious' category questions, but... is it possible to break a line of text into two or more lines within a single frame? When I try to do that, using the enter/return button, it kinda assumes that I've finished with that frame and am ready to proceed.
Advice appreciated - thanks!
VikingAnimations
processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
ram: 4 GB
Hard_Drive_Capacity: 1 TB
Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Post by VikingAnimations »
Using the enter key should work... it does for me, anyway.
All you should have to do is type in the first line, hit enter, and keep typing. Make sure the cursor is visible and blinking in the text entry area when you hit enter.
km
Post by km »
Ah! Mystery solved - many thanks! It was because I was always typing in upper case by holding down the Shift Key, which I also held down when I pressed Enter - which is why it wasn't working.
Pressing the Enter key on its own does indeed split the lines of text.
A huge DOHHHHHHHHHH from me. Thanks for that!
VikingAnimations
ram: 4 GB
That would do it! :)
You're welcome!
