Problem VS10+: Audio Clicking Sound every second
Posted: Sun Apr 08, 2007 10:42 pm
I have been using VS10+ for a while without any problems with DV or some movies from my digital cameras. But I am having problem with a new digital camera, Panasonic TZ1, I bought. The movies from TZ1 is Motion-JPEG in mov quicktime container. The Audio is recorded as 8bit Mono at 8kHz. When I render each clip individually - no problem at all; comes out perfect.
But once I start to join two or more clips together, some of them would have this loud clicking sound, exactly one click per second. I have tried various Audio settings at project properties: including Dolby (tried various bit rate), MPEG (tried various bit rate) and LPCM. I still get clicking in each of them - but may not be at the same clip or places.... very strange. I also tried splitting the audio... tried "Normalize sound"... no change. And the clicking can be heard from the "Create Sound File".
I have uploaded some samples to illustrate the clicking:
The first sound file is from 3 clips, no transition effect. The second clip (25s in length) started from 15 s; and the clicking sound can be heard until the 3rd clip started at 40 s. The original clips have sounds from TV, and some sounds from the Autofocus and Zooming, and some sound from me fiddling with the controls. wma format (135kB)
http://www.geocities.com/no_nosnoop/Click01.wma
If I just render the second clip alone, no clicking: wma (75kB)
http://www.geocities.com/no_nosnoop/Click02.wma
System: PC Windows XP
Settings: Audio: stereo
NTSC 29.97 frames / second
Frame type: Frame based
Frame Size: 720x480 4:3
Compression: NTSC DVD
Quality: 100
Variable 8000kbps
Audio: LPCM
Original File: Motion JPEG, mov
640x480 30fps
8bit Mono 8kHz
I would appreciate any pointers, TIA.
Quality: 100
Variable 8000kbps
Audio: LPCM
640x480 30fps
8bit Mono 8kHz
