no video capture
jinserra
no video capture
Post by jinserra »
New digital video guy here. Own a Panasonic Digital Video Camcorder (PV-GS36) and acquired ULead Video Studio 9.0SE along with a Firewire Card (StarTech) that claims to be compliant with IEEE-1394, 1394a and iLINK.
I just used the camcorder for the first time (filled the tape), then installed the VS9.0, and immediately plugged my camera into the FireWire port and attempted to capture video. I received the error message below:
"Either no video capture driver is installed in this system or no device is connected."
I've searched the KB and other posts to no avail. I appreciate the help.
roy wood
Post by roy wood »
Hi John first step will be to check that your 1394 card is installed OK.
Start>Settings>Control Panel>System>hardware>Device Manager>
(a) click-Display Adapter (Tell us what your Graphics card is).
(b) clk - IEEE 1394 Bus Controller (See if there is a Yellow ? or ! mark there)
Do the same for Sound Video & Game Controller and System Devices.
Feedback after members have endeavoured to help you is not only good manners it also helps others to know if a given solution was effective. Thanks.
jinserra
additional info
Post by jinserra »
Here is the additional info requested:
a) NVIDIA GeForce4 Ti 4200
b) all hardware appears to be working fine (I checked them all as requested)
roy wood
Post by roy wood »
OK Now lets see if it's Ulead at fault.
Windows has it's own Video Editor;
Connect up your Camera Start > Programmes > 'Windows Movie Maker' Go into File > Capture Video and see if your Camera is listed. If it is try a short capture.
Post by Black Lab »
Was the camcorder already on when you plugged in the firewire cable? Did you try turning the camera off, then back on again?
