Seems slow opening
bodkin button
Seems slow opening
Post by bodkin button »
I now have the full version of Video Studio up and running and have been reading all the tutorials about work flow and I'm afraid I still have more questions. :oops:
I'm making a 5 minute music video type project and using small clips from DVD's which have been saved onto my hard drive then placed into the library.
Everything was going well, but the more clips I added the slower and slower Video Studio became in loading the project and in doing further editing like adding effects and moving clips around. Sometimes I could select a clip to alter and have to wait up to 2 minutes for the clip to become "active" and again when I tried to nudge it along a little.
I'm saving often and on major changes save as a different file number - although the program hasn't actually crashed, several times after I've saved and closed, when I start again the next day VS wants to reclaim the last project I was working on, so something isn't happy.
I've turned everything else off I can, even the virus scanner - turning back on after a restart.
I am wondering if I've been doing the right thing as far as making the clips goes? I've just been trimming with the trim handles and then dragging the file the clip came from onto the time line from the library - usually onto an overlay track so I can position them. Then I choose another clip, sometimes from the same file, but sometimes from another and so on and so on.
What I need to know is - should I save these clips as trimmed clips or is it OK to keep using them and others from the original file? Is this what is slowing everything down?
If I do save them as trimmed clips can I still drag them out a little bit if I've got the timing a bit wrong? Right now I'm using the black arrow to add to the time or shift clicking for the white arrow to slow down the clip as it were to fit the music.
I eventually finished the project and it rendered quite quickly and played well, but the last couple of days of tweaking were quite a struggle waiting and waiting for the program to respond and I'm wondering if any one has any tips that might help me.
Post by Black Lab »
In Preferences, what do you have your playback set for - Instant or High Quality?
bodkin button
Preferences are set for Instant Playback and playback target is set for Preview Window.
Video Studio is on the Windows C drive and all the video is stored on the 160GB hard drive D.which I think is the right way of doing things.
I have moved the working folder that VS created to the D drive as well, could this be a problem? VS created it in my Documents drive (E) which is a bit full and I browsed to the D drive and created a folder there.
The Smart proxy was originally turned off - I enabled it when I was getting the slow down, but it didn't make any difference, but I wonder if I can't do this half way through a project? For my next project should I enable it from the start?
The 'cache image clips in memory' in preferences is also unchecked, as default would changing this help? Or are image clips still images? Sorry I'm still a bit unsure of the terminology for video.
The undo level is set at 99 which I don't need, should I reduce this to about 10 or so as I usually prefer to keep separate file numbers than undoing to much, but I'm more used to building layers on still photographs than video editing and that was my preferred method then.
NoM.O
Post by NoM.O »
bodkin button wrote:The undo level is set at 99 which I don't need, should I reduce this to about 10 or so...
Hello again,
I haven't a clue what the solution to your problem may be so I won't pretend to offer advice, except to say that this sounds like a good idea to me. If you're adding lots of transitions, tiles, etc, VS will have less memory available if you have the undo number set too high. Although, I would have thought 2GB of RAM would be more than sufficient for most tasks, so I might be way off base.
peace.
bodkin button
Hey, I'm glad for any thoughts at all on this as I want to try a new project soon and a smoother and quicker working condition is what I'm aiming for, so I'm willing to try most things as I'm having so much fun with this.
I am going to reduce the undo as I'm never going to use 99! :)
Thanks for the input.
