The video is fluid but ...
Nebbia
Post by Nebbia »
Hello to all, again me with another question.
I have make a video with 3d program, 30fps, to introduction the real movie .
When i play it with normal video player the moviment is fluid but when i drag in the Ulead Video Studio and i play it, the movie is not fluid. Why this ? Where is the problem ?
(The problem is more visible when the camera move left to rigth)
Are you trying to preview this in Project Mode? If so this is very common. VS must throw everything together "on-the-fly', ie; it is not rendered. This is very demanding on PCs. You would need an extremely powerful PC in order for this to be real smooth. Then to add to this burden you place, a 3D video into the mix. 3D video has to be the most demanding on PC resources. If you have anything running in the background, then this preview more then likely will not be smooth.
What format is:
1. Your 3D video, and what program was used to create it?
2. Your video files (other then the 3D) being used in VS?
Have you tried rendering (Share>Create Video File) to see if you still have the problem? I think that once it is rendered, it should play fluidly.
