How many installs?
rlphoto
How many installs?
Hello, I have more than one computer in my home and was wondering how many different computers I can install video studio on. This info is no where to be found in the FAQs.
Thanks!
Randy
Thanks!
Randy
railroadguy
Correct. Since VS does not "phone home" as part of the install you will be OK. At one time I installed Photo shop on my desktop and laptop, because I can not be using both at the same time, I was probably OK doing this. Now however, Photo shop also "calls home", so when I am on the road and need to do a job I have to fall back to an older version on the laptop.Ken Berry wrote:As with almost any piece of software of which I am aware, unless you are specifically buying a licence for multiple computers, the EULA means that you can only install a single copy of VS on one computer. But I suspect you won't have the thought police knocking on your door...
rlphoto
Did you know that you can have two installs with PS CS2 and it is perfectly OK with them. Since most pros have a desktop and a laptop both. And it is very easy to deactivate one of them and activate it on a third machine. I have CS2 and I have it legally activated on two machines.railroadguy wrote:Correct. Since VS does not "phone home" as part of the install you will be OK. At one time I installed Photo shop on my desktop and laptop, because I can not be using both at the same time, I was probably OK doing this. Now however, Photo shop also "calls home", so when I am on the road and need to do a job I have to fall back to an older version on the laptop.Ken Berry wrote:As with almost any piece of software of which I am aware, unless you are specifically buying a licence for multiple computers, the EULA means that you can only install a single copy of VS on one computer. But I suspect you won't have the thought police knocking on your door...
Which is why I was wondering about video studio. I have no intentions of letting all my friends install it because It is cheap enough for them to go and buy if they want it. But, I have several computers under a single owner, "me" and I shy away from software that locks me down to one install. It was my understanding that Adobe created elements hoping a cheaper version of PS would entice people not to hack PS so much.
Thanks!
Randy
- ram: 2 GB
- sound_card: Intel GMA 950
The end user Licence Agreement is found in your installation disc/folder and is named license.txt.
Ulead Systems Inc.
End User License Agreement
NOTICE TO USER: THIS IS A CONTRACT. BY INSTALLING THIS SOFTWARE, YOU ACCEPT THE TERMS AND CONDITIONS OF THIS LICENSE AGREEMENT.
1. Intellectual Property Rights: This software program (the "Software") and the accompanying written materials are copyrighted and are proprietary products of Ulead Systems, Inc. The Software is also protected by United States Copyright Law and international Treaty provisions. Trademarks shall be used in accordance with accepted trademark practice, including identification of trademark owner's name. Trademarks can only be used to identify printed output produced by the Software. Such use of any trademark does not give you any rights of ownership in that trademark. Except as stated above, this Agreement does not grant you any intellectual property rights in the Software.
2. Use of the Software: You May:(1) use the Software on any single computer, provided that the Software is in use on only one computer at a time. The software is " in use" on a computer when it is loaded into the temporary memory(i.e. RAM) or installed into the permanent memory (i.e. hard disk) of that computer. (2) make a single copy of the Software solely for backup or archival purposes. (3) permanently transfer all your rights to use the Software to another person or legal entity provided that you transfer this Agreement, the Software, and all accompanying written materials, provided that you retain no copies of the Software or written materials and that the other party agrees to the terms of this License Agreement. You May Not: (1) make, or have made, any form of copy, whether digital, printed, photographic or otherwise, of the Software, except insofar as such Software may be incorporated by you into on-screen or printed material. (2) place, or have placed the Software on an electronic bulletin board or other form of on-line service. (3) use, or have used, the Software in any form of pornography, or in any matter which is in any way defamatory of any person or business entity in any such image, or which implies any form of endorsement by the Software, its suppliers, its licensors, or any individual or entity depicted in the Software . (4) reverse engineer, decompile or disassemble or otherwise attempt to discover the source code of the Software. (5) modify, adapt, translate, rent, lease, loan or create derivative works from the Software. (6) export the Software in any form without the appropriate United States and foreign government licenses.
3. Term: This License shall continue for as long as you use the Software, except that it will terminate if you fail to comply with any term or condition of this Agreement. Upon such termination,or in order for you to terminate the Agreement, you agree to destroy the original and any copies of the Software.
4. Limited Warranty:
A. Ulead warrants that the original media which the Software is recorded will be free from defects in materials and workmanship, assuming normal use, for a period of ninety (90) days from your date of receipt. If a defect occurs, return it Ulead, along with a dated proof of purchase, and it will be replaced free of charge.
B. Ulead's entire and exclusive liability and remedy shall be limited to either, at Ulead's option, repair or replacement of the Software that does not meet Ulead's limited warranty or refund of the license fee you paid for the Software with a dated proof of purchase.
C. ULEAD AND ITS SUPPLIERS DO NOT AND CANNOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE OR THE ACCOMPANYING ITEMS. THE FOREGOING STATES THE SOLE AND EXCLUSIVE REMEDIES FOR ULEAD'S OR ITS SUPPLIERS' BREACH OF WARRANTY. EXCEPT FOR THE EXPRESSED WARRANTY SET FORTH ABOVE, ULEAD GRANTS NO OTHER WARRANTIES, EXPRESS OR IMPLIED, AS TO NONINFRINGEMENT OF THIRD PARTY RIGHTS, MERCHANTABILITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. NO ORAL OR WRITTEN INFORMATION OR ADVICE GIVEN BY ULEAD, ITS RESELLERS, AGENTS, OR EMPLOYEES SHALL CREATE A WARRANTY. Some states do not allow the exclusions or limitation of implied warranties, so the above exclusions and/or limitation may not apply to you.
5. Limitation of Liability:
IN NO EVENT WILL ULEAD BE LIABLE FOR ANY DAMAGES, INCLUDING ANY LOSS OF PROFITS, OR OTHER INCIDENTAL OR CONSEQUENTIAL DAMAGES, ARISING OUT OF YOUR USE OR INABILITY TO USE THE SOFTWARE OR WRITTEN MATERIAL, EVEN IF ULEAD HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. Some states or jurisdictions do not allow the exclusion or limitation of incidental, consequential or special damages, so the above limitations may not apply to you.
6. Miscellaneous:
This Agreement is governed by the laws of the State of California. If any provision of this Agreement shall be unlawful, void, or for any reason unenforceable, then that provision shall be deemed severed from this Agreement and shall not affect the validity or enforceability of the remaining provisions of this Agreement. This Agreement is the complete statement of the agreement and supersedes any proposal or prior communications between us relating to the subject matter of this Agreement. If you have any questions regarding this Agreement, you may contact Ulead at one of the addresses shown below.
Ulead Systems, Inc.
International http://www.ulead.com
North & South America http://www.ulead.com
Japan http://www.ulead.co.jp
Europe http://www.ulead.de
Ulead Systems Inc.
6. Miscellaneous:
Ulead Systems, Inc.
rlphoto
LGO
- motherboard: Intel Corporation D915PBL AAC67720-301
- processor: 3.20 gigahertz Intel Pentium 4
- ram: 3 gb
- Video Card: ATI Radeon X300-X550-X1050 Series
- Hard_Drive_Capacity: 200-750gb
rlphoto wrote:
Huh? Did you read the same thing I did?
Maybe I read things wrong. How do you interpret the second sentence of paragraph 2 in the EULA (the part Steve highlighted in red)?
So I guess that multiple installs is OK as long as they are not used by multiple users at the same time. Works for me!
Well I interpret it the same way as rlphoto - to me it quite clearly says there are no restrictions on having it on any number of computers as long as you only use one at a time.
If you are only allowed to put it on a single computer why is it necessary to say it can only be "in use" (loaded in RAM) on any one computer at a time, the stipulation is redundant if you are only allowed to install it on one computer.
I beg to differ. It states it is "in use" if it is installed to the HD. If you install it on 2 computers, it is "in use" on 2 computers which, by their definition, is in violation.
But to me, having it installed on 2 different computers, and using it on 2 different computers simultaneously, are two differents things. As Ken stated, you won't have the police knocking on your door.
As for the redundancy of the statement, whoever wrote that obviously was from the Department of Redundancy Department. (A Monty Python gem
Jeff
Dentler's Dog Training, LLC
railroadguy
Yes my friends, another example of lawyers helping lawyers. The ambiguous way this is written, and most EULA's are, is open to interpretation.
They could say "you allowed to install this software on ONE computer and must be uninstalled from said computer if installed on another", but that is way to easy and no lawyer would ever write that.
I agree with BL, and if you don't try to read into it, what is not there, then it is clear. Of course I've had years as a law enforcement officer, where I've had to constantly try to figure out legal nonsense.
1. It states that you may use on any Single Computer.
2. It may be in use<---Those are the key words that the EULA uses,
3. On any one computer, at a time.
Now what the EULA does is provide a definition to In Use.
1. In Use is:
a. When it is loaded into RAM.
b. When it is installed<--Keyword again, onto a Hard drive.
So according to the EULA, you can only install it on 1 computer, because to use it, you must install it right...
However I've never tried running one of these applications via a server on a network. In doing so, it would be installed on just one computer, however could be accessed by any number of different computers. To stay inline with the EULA, only 1 of those PCs could access it (load it into RAM) at a time....
1. In Use is:
