Windvd 8 Platinum Problem
Moderator: lata
Cuz
Post by Cuz »
I have just purchased Windvd 8 platinum. It is being installed on a Windows XP operating system with a 2.16 Ghz. AMD Athlon processor with 1gb of memory. After installing the program I always get the following popup message when I try to start the program.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program:C:\ProgramFiles\Intervideo\DVD8\Windvd.exe
abnormal program termination
When I click ok on the popup box the program immediatly ends.
I have uninstalled and reinstalled the program twice and always completely deleted the folder that is left in Program Files. I even redownloaded the program from Intervideo's website and doing a clean reinstall.
I always reboot the computer when uninstlling and reinstalling.
I also ran a system registry cleaner before the last reinstallation.
Still no success. The program will not accept my activation info.
I am not a newby with Intervideo products , I have successfully installed several of their programs with no problems. I am waiting for a responce from their Tech Support but I no joy yet ! Any help is greatly appreciated. Thanks
Jimruss1
Post by Jimruss1 »
ya i have the same problem cant figure it out
1. Launch Windows Explorer and go to tools\folder option\advance setting to check "show hidden files and folders".
2. Clean up temp files from\Start menu\Programs\Accessories\System Tools\Disk Cleanup.
3. Go to "C:\Program Files\InterVideo"
4. Delete the folder for "DVD8".
5. Delete the following folders:
"C:\Program Files\Common Files\InterVideo"
"C:\Program file\InterVideo\Common\Bin"
7. Go to "C:\Program Files\InstallShield Installation Information"
8. Delete the folders "{20471B27-D702-4FE8-8DEC-0702CC8C0A85}"
9. Go to Start-->Run and type "regedit"
10. Go to "HKEY_CURRENT_USER\Software\InterVideo"
11. Delete the folder "DVD8"
12. Go to "HKEY_LOCAL_MACHINE\SOFTWARE\InterVideo\"
13. Delete the folder "DVD8"
14. Close "Regedit"
15. Restart Windows then reinstall WinDVD 8
Notes:
1. You need to have "Administrator" privileges on your computer. "Limited" or or even "Power User" accounts won't let InterVideo software install or run properly on your computer.
i. Right click on your WinDVD 8 shortcut from the Desktop or Start menu.
ii. Select "Run as" and select "Administrator" as the user to run this program.
iii. Apply the changes and exit.
Bignickfly
Post by Bignickfly »
I did have a similar problem and I needed Windows installer for it to work
http://www.microsoft.com/downloads/deta ... laylang=en
Jimruss1
Post by Jimruss1 »
done that still nothing
Cuz
Post by Cuz »
sjj1805 ,
I followed your instructions to the letter. I could not find the folder or registry entry {20471B27-D702-4FE8-8DEC-0702CC8C0A85}. After doing everything you suggestd my computer became hoplessly locked in a loop----Windows installer was constantly trying to install Windvd 8 then a popup window would follow declaring that the installer could not find -- Windvd .msi --. I could not escape the cycle, I tryed rebooting and system restore points. I still had no control over the Windows Installer. I downloaded a fresh Trial Version of Windvd 8 .To no avail, try as I may I could not escape the loop that the installer was in. Please understand that I could not cancel it in any way.
Bignickfly,
I tryed the Microsoft download you suggested. When I attempted to install the update a popup window said that the installation wasn't need when Service Pack 2 is installed.
Fortunatly I constantly backup all of my files on an external hardrive regularly. The ultimate solution was a complete system restore.
I have just finished successfully installing and activating Windvd 8.
After using many dvd playback programs Windvd 8 has the best playback quality I have used yet. Too bad it isn't easier to install.
I appreciate your help.
Jimruss1
Post by Jimruss1 »
restore or format
t still cant get it to work
bloodygod
Post by bloodygod »
Cuz wrote:sjj1805 ,
Yes this instruction letter is *!*!*... many points can't be found. And I know what i mean, I am an computer administrator.
Cuz
Post by Cuz »
I performed a complete reinstallation of the Windows XP Operating System.
It is a drastic and time consuming thing to do , but as you all know it is the same as starting with a new computer. I do this a couple of times a year to get rid of all the residual garbage in the system. The increase in the speed of the computer is well worth it.
I just wanted to say this so there is no confusion as to what it took to get the problem solved.
Cuz wrote:I performed a complete reinstallation of the Windows XP Operating System.
A number of users do this. For those that do a time saving method is after initally setting up the operating system and drivers and other essential stuff, then create a disc image of your hard drive. there are various tools available to do this.
You can then at any time revert your hard drive to that state - sort of a system restore to a fixed moment in time.
Jimruss1
Post by Jimruss1 »
all that for one buggy program
Jimruss1 wrote:all that for one buggy program
No, I know quite a few people who like to re-install their operating system at least once a year. They claim it clears out the cobwebs and improves the speed and performance of their system. Personally I have my own housekeeping methods, but the hard drive image system is still worth passing on.
It may suit some users, though not all. The beauty of a User forum such as this is that we can all exchange different ideas and methods.
No one will claim that their system is better than another's, it is all about being given various choices. It's a bit like going to the newspaper shop and having more than one newspaper to choose from.
Cuz
Post by Cuz »
After paying sixty US dollars it was either do what I had to do or lose an investment. I am also looking forward to upgrading to HD DVD or BluRay HD when it becomes available. Besides that I really enjoy the challange of getting those buggy programs up and running ! I have never had one defeat me yet and I have had my share of them.
Jimruss1
Post by Jimruss1 »
ya i have done that allot in the past but it is still an extream fix for
something that should work
i have never had a problem with any other intervideo program in the past
i had to do a system restore to even get win dvd 7 to work after installing 8
