Have been using VS10+ for a while now and all of a sudden my prodjects wont play in high quality, they did before and i wonder if something might have changed them as i recently added Avid Liquid to my editing collection,
any help would be nice, thanks
Tony
High quality play back mode is disabled with current project
No it shouldn't, however view the properties of the DVD project settings. Pay attention to the Frame size, Bitrate, and audio. When you change it from the NTSC or PAL DVD to MPEG-2, the only change I noticed testing this, using an DVD compliant MPEG-2 I had created, was the audio switched to LPCM.
If anything changes when you change it to MPEG-2, when you are ready to create your video file, or create disc, just go into the Options and change it back to NTSC or PAL DVD. You really shouldn't have to do that, if all the properties are kept the same, because they should be DVD compliant. However you may wish to use Dolby 5.1 or AC-3, instead.
