Menu Missing
MrMax
Menu Missing
Post by MrMax »
As a new User starting with MF5 Trial :
Made some small DVD movies but after burning they all start up playing the DVD but no Menu at the start, there is a menu when I press the menu button.
Is this common or did I forget something?
I marked "Create menu"
Not marked " Use first clip as introductory video"
Next I run pre-render menu
Burning : Create to disk* , Create DVD folders* , Normalize audio*
When I not mark " create DVD folders" same no menu at the start.
What to do I want a menu at the start before I buy MF5 / 6
Please help me out
Max
It seems that you may have selected Play all Clips first before Menu. You need to click the gear-looking icon (lower left) and in the bottom section (Navigation Controls), uncheck that option.
MrMax
Post by MrMax »
vidoman wrote:It seems that you may have selected Play all Clips first before Menu. You need to click the gear-looking icon (lower left) and in the bottom section (Navigation Controls), uncheck that option.
Yes that box was checked have another try
Max
MrMax
Post by MrMax »
Thank again that solved my problem !
Another question has the version after you buy it more or the same menu templates?
Or is is possible to upload or design them
Regards Max
Generally the TBYB (trial versions) have fewer templates. I don't have DMF5 installed so I'm not sure just how many templates it has.
The current version available is DMF6 and DMF6 Plus, and it has I think 44 templates.
Also it is recommended that if you purchase, to not purchase an activation key, but purchase and download a full version, uninstall the TBYB, then install the purchased full version. This is due to problems with any update/patches recognizing the activated TBYB as full versions, and will not install.
MrMax
Post by MrMax »
vidoman wrote:Generally the TBYB (trial versions) have fewer templates. I don't have DMF5 installed so I'm not sure just how many templates it has.
Thanks again for your information it was very helpfull
Max
