How to set compression settings to get specific file size?
brodwidr
motherboard: Dell MoBo 0M3918
processor: Intel Pentium 4 3.00 GHz
ram: 1.5 GB
Video Card: NVIDIA Quadro PCI-E Series
sound_card: built-in
Hard_Drive_Capacity: 75 GB
Post by brodwidr »
I need to render a finished project to an MPEG2 formatted file with a specific file size limit (in this case, 200MB) and I am getting larger than than that using the VS defaults.
I have tried different options, like smaller frame size and slower refresh rate and am not making much progress.
Rather than do this by trial and error, is there a tutorial or other advice as to how I can specify the maximum file size, and quickly find the combination of paramters that let me achieve it?
thanks,
David
VS 10+, windows XP pro SP2, Dell Dimension 4700 P4 3.0 GHz, 1.5 GB RAM, 40GB and 250GB SATA HD, Nvidia Quadro Duo.
Post by Black Lab »
Have you tried a Bitrate Calculator?
brodwidr
ram: 1.5 GB
how to use bitrate calculator
Post by brodwidr »
Is this the right work flow:
Share tab > create video vile > custom
Save as type > select MPEG-4 Files (*.mp4)
options... > compression tab >
enter the calculated bit rate in the "video data rate" field
brodwidr
ram: 1.5 GB
that worked
Post by brodwidr »
That works! Thanks, Black Lab
Post by Black Lab »
8)
