Hello
I run MPS5.5 and am considering changing to MSP7. I have installed MSP7 Trial on another machine to test it but have decided not to purchase at present because I need to travel abroad for a month. Does anyone know how to uninstall the Trial version from a pc? I can't find any uninstall prompt.
If I just leave it there, will it all 'disappear' after 30 days, and will I be able to continue the trial later when I am able.
Thanks for any help.
Uninstalling MSP7 Trial
htchien
Open Control Panel->Add/Remove Programs and look for MSP 7 Trial, and then click on it and click on Remove.
If you leave it there, it will not disappear automatically after 30 days. You must uninstall it.
And, once you installed it, no matter how many times you install/remove the trial program, the 30 days limit will be still existed since the first time you install the trial version. The only way to remove the limitation is to format your disk and reinstall the Windows from the scratch.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
After uninstalling as stated, there will still be a load of junk in your registry. If you have no other Ulead applications installed, I suggest you use any registry editor and delete any key you can find that contains "MSPro", "MediaStudio", "Ulead" or any reference to the directory name where you installed it. Usual prior backup precautions, of course.
If you have other Ulead products installed, do NOT search for "Ulead"
