Is there a tutorial on using bend?
I have a square object I drew in the image editor and I'm trying to give it a small curve, just enough so that it's not flat. But so far, all I get are extreme bends.
Cool 3D 3.5 - Bend Plugin
dnavarrojr
- VikingAnimations
- processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
- ram: 4 GB
- Hard_Drive_Capacity: 1 TB
- Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
If you look at the bottom of the screen, you should see various settings there. Look for the one called "Level" and scale that back to 10 or less. That will reduce the amount of the bend.
You don't have to select a preset bend shape. Just click the F/X button at the bottom and start changing the settings - Direction, Type, Level, Cutting Point...
If there are tuts for this, I have not seen them. I just poke around!
