First of all this programs rocks but im havaing a bit of trouble
1- when i want to burn a project well in my preview screen i have some sound but as soon as i put it opn dvd there is no more sound ?????6
2- i cant burn any video they have to be in (DivX® 6.5.1 Codec (1 Logical CPU)) and sound mpeg-layer 3 but like i said if i put them on dvd i have 2 sec of sounds
3- last but not least when i extract dvd scenen they alwayz put them at 1,3 gig is there a way to play with the size
thanks for your help
Trouble burning finish result not good
These types of problems are usually caused by a bad source video, or by a "strange" highly compressed format. These formats are really just designed to be watched on your computer. They can potentially cause all kinds of trouble if you try to edit or convert them. What format are your files, and where did they come from? The Read This First... post tells you what we need to know to help you.1- when i want to burn a project well in my preview screen i have some sound but as soon as i put it opn dvd there is no more sound ?????
If they are all DivX files, you may need to look for some special DivX software. SVCD 2 DVD (~$40 USD) claims to be able to make a DVD from almost anything. Or, you can try using a 3rd-party program like SUPER (FREE!!!) to convert the file to DVD compatible MPEG-2 before bringing it into Workshop.
Also, you should be aware that there will always be some quality loss when converting from one lossy compresion scheme (DivX/MPEG-4) to a different lossy compression scheme (DVD/MPEG-2).
You are not trying to make a DivX DVD are you? You can copy the DivX file directly onto a DVD as-is with any burning software. (You don't need DVD authoring software for that.) You can play that DVD on a computer with a DivX codec, and on some DVD players, but it will be a non-compliant DVD, and most stand-alone players won't play it.2- i cant burn any video they have to be in (DivX?6.5.1 Codec (1 Logical CPU)) and sound mpeg-layer 3 but like i said if i put them on dvd i have 2 sec of sounds.
The file size is determined by the bitrate (audio & video combined) and the playing time. (Bitrate is kilobits per second, and this can be scaled-up to Gigabytes per hour.) 1.3GB is probably about right for a DivX movie, but that's way too small for a DVD (MPEG-2) movie which should approximately fill-up a 4.3 GB single-sided DVD (depending on the bitrate). Here's a Bitrate Calculator.3- last but not least when i extract dvd scenen they alwayz put them at 1,3 gig is there a way to play with the size
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
DonjuanDMofo
Re: troublw burning ......
First Thanks for the response but nothing is working
here ill detail the file i want to burn
Here the files that burns and has sound
And now for the file that has no sound when its burned ( in the program i have sound)
This is exactly what the info on the files are when im in dws
Cause before i had problem with my computer well everything went great but now since ive redone my computer is doesnt work no more
What could be wrong
program interference?????
not powerful enough ????
or should i just give up
thanks in advance
Code: Select all
-File-
File Name : Cartman's Silly Hate Crime
File Format : Microsoft AVI Files -- OpenDML
File Size : 174 532 KBytes
Frame Rate : 25,000 Frames/Sec
Duration : 1321.000 Seconds
Data Rate : 131.40 kbps
-Video-
Compression : DivX 6.5.1 Codec (1 Logical CPU)
Attributes : 24 Bits 512X384
Total Frames : 33025 Frame(s)
-Audio-
Compression : MPEG Layer-3
Attributes : 128 kBits/s, 48,000 Hz , Stereo
Total Samples : 63 406 728 Samples
Code: Select all
-File-
File Name : Title_01
File Format : Microsoft AVI file
File Size : 215 700 KBytes
Frame Rate : 29,970 Frames/sec
Duration : 1314,781 Secondes
Data Rate : 162.36 Kbps
-Video-
Attributes : 24bits 720X480
Total Frames : 39 404 Frame(s)
-Audio-
Compression : Mpeg layer-3
Attributes : 128 kbt/s, 48,000 Hz, Stereo
Total Samples : 164 343 Samples
What could be wrong
thanks in advance
Code: Select all
If they must be MPEG-4(avi) DivX, then they can not be put on a DVD in that format. DVD specs must be MPEG-2. The only other option that I know, is to purchase DivX Author. It allows you to create menus, so that it will play on a DivX certified DVD player, just like a traditional DVD.
You can burn your DivX video files to a DVD, however they will only play on a DVD player that says it can play DivX. AFAIK, none of Intervideo-Ulead's applications can build DivX menus, so creating a DVD (building menus) is not possible.
DonjuanDMofo
Re: trouble burning ....
well thanks for the advice but still cant do anything and im losing patience to get my files im using imtoodvdripper and still nothing now in mpeg-2 theres no image
is there any other software like dws that i can create my own pages for dvds or its the only one cause i cant figure out what this !@#!$ problem is
thank you
thank you
Your working file looks like PAL (Europe, etc.) 25FPS @ 512x384.
The non-working file looks like NTSC (USA, etc.) 29.97 FPS @ 720x480
But, that alone should not prevent you from making an NTSC or PAL DVD, and it does not explain the audio issues.
But, since there are many variations of every video format, you won't know if a particular program works with your particular files until you try it. The best solution is to avoid these highly-compressed formats altogether... or, just watch them on your computer.
There are variations of MPEG-2 also. Some of those variations are valid for PAL DVDs, and other variations are valid for NTSC DVDs. Some are not DVD compatible at all! And, an MPEG-2 A/V file can contain various audio formats. Again, some audio formats are DVD compatible and some are not... MP3 (AKA MPEG-1 layer-3) is not DVD compatible.
I don't know much about the ImToo DVD Ripper, but I would expect a "DVD Ripper" to convert from DVD to DivX (or some other format). I wouldn't expect it to convert to DVD from some other format...
Of course there are alternatives, starting with Ulead Movie Factory, which is more up-to-date than Workshop, designed to work with DivX files, and less expensive than Workshop! You can also try Roxio, Nero, Sony, Adobe, or just search the Net for "DVD authoring software".is there any other software like dws...
No time to think.
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
