Workshop beginning in middle of Video instead at first menu
simmerheli
Post by simmerheli »
I just created a DVD with several menus. When I use the DVD Workshop simulator to play the DVD, it begins appropriately at the first menu as expected. :D
However, when I insert the DVD into a player, the DVD begins about halfway through the movie instead of the first menu. :?
At this point I can press the top-menu button and the first menu is played as it should have been when I first inserted the DVD into the player.
How can I get the DVD to play the first menu like it should when I insert the DVD into a player?
-Mike
simmerheli
Discovered the problem.
The DVD player I was using is a portable DVD player.
I disovered that if I insert the DVD and then power on the player, the movie will begin somewhere in the movie itself (randomly).
However, if I power on the player first and then insert the DVD, the first menu is played as expected.
I also tried this on a non-portable, standard type DVD player and the DVD works correctly each time.
So... problem solved. :-)
-Mike
niki516
Post by niki516 »
It's the DVD player problem not DVD Workshop. Thanks for the sharing. :lol:
