Error message HELP!!
lank43
I'm using VS10 on my pc with XP. I Consistently get this error message, but only when I click on the "borders/Shading/transparency button: "The instruction at 0x73dd11c7 referenced memory at 0x00000004. The memory could not be read. Click OK to terminate the program. When I click OK, sure enough it terminates the program. Everything else in my VS10 works fine. Any ideas how to fix this??? TIA.
- ram: 2 GB
- sound_card: Intel GMA 950
Check the Windows Event Log for error messages:
START | RUN dialog box
%SystemRoot%\system32\eventvwr.msc /s
and press enter.
Now check the following two folders
Application
System
You will find a red circle with a white cross inside. Double click to open it and there you will find a link
http://go.microsoft.com/fwlink/events.asp.
This link also contains some hidden code appertaining to your error.
Double click and you will then be given more detailed information and possible cures.
and press enter.
Application
System
