I upgraded from version 3.0 to version 4.0 last evening.
I have a P4 3.4GHz processor and the new version runs real slow and appears to have a lot of problems - including crashing when I select the TV Tuner as an input device. The software recognizes that the tuner is present; however, I can't use it.
In version 3.0, that was a patch for this tuner. Does anyone know if there is a similiar patch for version 4.0? Or better yer, has anyone gotten this type of TV tuner to work with this software?
DVDMF V4.0 - Hauppauge WinTV-PVR-USB2 - Usageage causes cras
htchien
Do you have a copy of DVD MovieFactory 3? Or you bought DVDMF 4 directly?
I think you can also ask Hauppauge Tech Support to help to provide the updated capture driver.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
G-Omaha
htchien
Sorry I did not read your problem properly.
I will help to report your problem to Ulead and see if there will be an solution.
H.T.
H.T.
Ted (H.T.)
G-Omaha
