When I click on a picture and it opens in Photo Explorer 8.5, a noise comes
from my floppy drive like it is trying to open the file from a floppy disk.
I have uninstalled the program and re-installed it and still have this problem.
Photo Explorer 8.5
After using a floppy, PEX now defaults to a floppy at the next start up.
Insert a floppy in to Drive A and restart PEX. After PEX has check out the contents, go to a folder on your C drive (or D or E or whatever, check it out and shut PEX down. The default has now been reset to that folder in that drive.
bmausti
Noise from Floppy Drive-Photo Explorer 8.5
Thanks Bobm03. I tried what you suggested and that did not work.
The program is making the noise like when you go to the A drive and
there is no disk in it.
htchien
Try this in PhotoExplorer:
Select File->Preference->General->Always start program in and then change the startup folder.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
bmausti
Photo Exolorer 8.5 & noise from Floppy Drive
I believe it is finally fixed!! I did as HT suggested and changed my settings in preferences . No noise from floppy drive now.
Thank you so much HT!
