Hi, I am using VideoStudio 10.
I am trying to add an additive dissolve to the beginning and to the end of an introductory slide (i.e. It dissolves in, 5 secs later, it dissolves out).
So what I do is I click the title slide. Go to "Animation". Check the "Apply Animation" Box. And tab it to "Fade".
Now I am given a bunch of templates, none of which dissolves in and then dissolves out. I found one that dissolves in and another that dissolves out, but they are 2 seperate effects, and I still don't know how to apply 2 effects to one title slide.
Help! :x
Thanks!
Adding more than one effect to a title slide
basically you don't do it that way - just create two identical titles (easiest done by creating one - then dragging the text block up from the timeline into the 'Title' library - where it will create a thumbnail - then dragging the thumbnail back down to the timeline next to the first one) Then apply fade in to the first and fade out to the second - if it does not stay onscreen long enough to read put a third copy of the title in the middle and do not apply any animation to it.
