I am currently creating a movie of a recent trip and I have overlaid a map and set Chroma Key and set the similarity to 11% to mask out the background. After rendering I noticed that there are diagonal stripes of light green over the darker green.
What has caused this and what is the method to ensure that I don't get these diagonal lines.
Here is a screen shot to illustrate
John a VS X10 Ultimate, Paint Shop Pro 2018 Ultimate, Audacity, Panasonic HC-X920M, Nikon Coolpix S8100
You have to use the de-screen filter on your scanner to eliminate the effect. It is something to do with the printers saving ink and only printing half of the paper - your eyes don't see the missing ink but as can be seen from the above examples, it is revealed when scanned.
Thanks Steve,
Yes I did use a scanner and I also scanned it at 600dpi as I originally intended to use pan and zoom. I am at present rescanning at 150dpi )which results in an image with resolution of the 'native' 1024 x 576) to try and get around the problem. Maybe I will also try setting the 'region' (during scanning) as a colour drawing rather than a colour photograph.
I will check out the links you suggest and see if I have a de-screen filter on my scanner but I cannot ever remember seeing it.
I cannot find descreen (or de-screen) anywhere including the HELP.
I also checked the HP web site which shows the de-screen feature but NOT for my model.
I have an older scanner (HP Scanjet 5200C).
Do you have a nice simply map of scotland?
