Multi-trim video crashes oddly VS10.plus
sunshynevideo
Post by sunshynevideo »
Been using Video studio since version 7. Nice easy edit program
Seems like I run into a problem using the multi-trim function lately.
I can move a clip to the time line and edit it using multi-trim. Works perfectly. If I try to do a second clip ulead gives an error and closes. I doubt the computer is the problem as it is a power house.
Checked my logs and get the following errors after the crash
faulting module unknown, version 0.0.0.0, fault address 0x0c5bbd60.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 76 73 74 ure vst
0018: 75 64 69 6f 2e 65 78 65 udio.exe
0020: 20 31 30 2e 30 2e 30 2e 10.0.0.
0028: 30 20 69 6e 20 75 6e 6b 0 in unk
0030: 6e 6f 77 6e 20 30 2e 30 nown 0.0
0038: 2e 30 2e 30 20 61 74 20 .0.0 at
0040: 6f 66 66 73 65 74 20 30 offset 0
0048: 63 35 62 62 64 36 30 0d c5bbd60.
0050: 0a .
Event Type: Error
Event Source: Application Error
Event Category: None
Event ID: 1000
Date: 3/20/2007
Time: 9:22:41 PM
User: N/A
Computer: SERVER
Description:
Faulting application vstudio.exe, version 10.0.0.0, faulting module ac3filter.ax, version 1.0.1.0, fault address 0x0002bd67.
Data:
0028: 30 20 69 6e 20 61 63 33 0 in ac3
0030: 66 69 6c 74 65 72 2e 61 filter.a
0038: 78 20 31 2e 30 2e 31 2e x 1.0.1.
0040: 30 20 61 74 20 6f 66 66 0 at off
0048: 73 65 74 20 30 30 30 32 set 0002
0050: 62 64 36 37 0d 0a bd67..
Post by Black Lab »
Does it only do it on this one clip, or have you tried using it on others?
sunshynevideo
Black Lab wrote:Does it only do it on this one clip, or have you tried using it on others?
Yes all clips... I work with about 30 different content clips a day. Does not matter. 1st clip always works fine but when I move the second clip to the time line and hit multi-trim it crashes.
