Exceeded Video File Size. Need More VCD Space.
programmer395
I've created a video with duration which is approx. 84 minutes.
All of them was needed by me.
The question is, as we know, VCD can only contain only 77 minutes or more of video tracks. I really needed that video to be composed in one VCD.
What task must i do instead of cutting the video? such as using another video's format or etc.
Please help me...
Please help me...
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
I have never used VCD but have created a few miovies in SVCD some years ago and played around with video data rates.
I am not sure if VCD allows different video bit rates (SVCD does). You could try rendering at a lower bit rate. That would result in a shorter file to fit a CD (VCD).
You would need to create a new "movie template" using TOOLS > MAKE MOVIE MANAGER.
Standard VCD is 1150 kbit/sec so try 1050 kbit/sec but REMEMBER the resulting video quality will not be as good.
Have a look at this web site for more information on VCD.
John a
- jparnold
- ram: 16GB DDR3
Sorry about the double post but I accidentally selected QUOTE instead of EDIT.
Standard VCD is 1150 kbit/sec so try 1050 kbit/sec (if VCD will allow it) but REMEMBER the resulting video quality will not be as good.
If that is no good consider using DivX but as VideoStudio doesn't support this you would need to output in a supported format and then convert to DivX.
John a
I would agree with most of Johns reply but I seem to remember reading somewhere that in order for a VCD to play on a DVD player the bit-rate needs to be kept at 1150kb/sec. If you use a CD re-Write disc you could try it and see.
Feedback after members have endeavoured to help you is not only good manners it also helps others to know if a given solution was effective. Thanks.
You should be able to get around 80-minutes on a 700mb CD-R (created/burned properly as VCD). I know I once overburned 82-minutes of VCD to CD-R -- but don't do it unless you know for sure it will fit.
They do sell some larger capacity CD-R's (I think I once saw 900mb CD's -- but I don't recall where I saw them...)
George
George
programmer395
You don't need any other software.
Actually you can do it, requires re-encoding your mpeg file and some tricks of the trade.
I make vcd's just because of the mpeg audio at mpeg2-16bit-224kbs is great quality.
Some of them are 113 minutes to 120minutes burnt onto a standard CD.
You do sacrifice quality in the video when re-rendering of course.
But the audio is the same quality and vcd has great audio quality.
For simplicity and to create a video that will play in almost all dvd players for you to distribute I would re-render your video from
352x240 VCD Mpeg-1 to 352x240 Mpeg-2 Dvd Compliant, same constant bit-rate, aspect ratio, frame-size & audio spec's
(You may want to use Lpcm Audio on the dvd for the most compatibility, in this case I would).
Use the Mpeg2 file and create a dvd. You could even put more on the dvd.
Dvd's are more compatible, vcd's will not play in all dvd players.
programmer395
programmer395 wrote:![]()
I think my audience will not prefer to get my video in DVD format,
in the use of DVD will increase the price.
any other suggestions?
How will using DVDs increase the price that much? Since DVDs have been around for a while, they really are not more expensive then CDs. IMHO CDs will probably be going be the wayside in the near future, just like VHS and audio cassettes.
heinz-oz
AFAIK, the argument is futile since the VCD standard stipulates mpeg1 and a certain bit rate. Apart from lowering the already bad video quality by using an even smaller frame size, I don't know of any way to make the file size smaller. Why does it have to be VCD
I haven't used VCD at all, did one trial project and didn't like the quality at all. Until I got my first DVD burner I only created SVCD which allows even less video duration by the pure nature of it.
I don't know who your audience are but, I fear, they are as ill informed as you are. If you are restricting yourself to the CD format, try mpeg4, Xvid, DivX etc. The file sizes are very small at an excellent video quality.
Where are your "creations" played?
Exactly, that's why I'd rather not post a hacked work around. May not play on all dvd players that can play VCD disks. Even if you leave the framesize correct lowering the bit-rate can cause player problems. Some players just can't do it.AFAIK, the argument is futile since the VCD standard stipulates mpeg1 and a certain bit rate. Apart from lowering the already bad video quality by using an even smaller frame size, I don't know of any way to make the file size smaller. Why does it have to be VCD Question
It's not worth bypassing the VCD spec unless your making one that you will know your player can handle. VS can do this though.
VS can also burn SVCD(slight modification to the audio) to DVD without re-rendering, same case though, may not work in every dvd player.
Sometimes that's just the way it is.
programmer395
i know that DVD is better and i will prefer DVD if there is a choice for me. but, in this case, my audience is quite "reversed" in today's video tech. Most of them only have VCD player. and they rather not to prefer DVD than VCD if we give them choice. As an example, in my country VCD is sold at RM5 (RM is currency in my country) while DVD is sold at RM10 per disk. I couldn't handle their mind set which said that DVD is more expensive than VCD.
programmer395
