Does Movie Factory 4 Allow insertion of Chapte Points
JJordan
At any point you want them. I have Movie Factory 2 and quit trying to make home movies into DVD's because I found no easy way to put chapter points where I wanted them. If you capture every "scene" then the kids' birthday party where you stop the camera 20 times is 20 chapters. And no two events are the same length or even claose so putting them in by time is worthless too. Does the newer software let you insert a chapter point wherever you want it in a captured video?
Merlin
This is as I do it in Movie Factory 3 (and looks like it will work in 4 as well, I have 4 but I haven't installed it yet)...
I always capture using the "split by scene" feature. But sometimes I want different chapters than the split scenes, so you can join clips together on the timeline. Each joined clip being a main menu item, which can be enabled to navigate to a sub-menu. Go to Add/edit the chapter points for the sub-menu, MF3 automatically sets menu items for each joined video, but you can remove them and add others as you want with one exception - the first clip is always on the menu.
I hope I explained this good enough. It sounds much more complicated than it actually is.
Bill
Bill
Yes. Just follow Merlin's suggestion above. I had MovieFactory 2 SE and I did it numerous times. I never split the videos into scenes. I just insert the chapter points wherever I want them. It's very easy.JJordan wrote:So you can add chapters anywhere and they show up on your main menu screen on the DVD?
JJordan
maddrummer3301
It you want all the chapters to show up on the main menu
which many people like.
1 - Click on Advanced.
2 - Uncheck "Add Title Menu"
3 - Check "Create Chapter Menu" (should be checked off by default).
Some Tips:
Motion Menus are always checked on by default.
To change the default to "OFF" change the setting in the following file:
SET MOTION MENUS TO DEFAULT OFF
FILE -> DVDMFEnc.ini
[DMF_ENC] <section>
MotionMenuCheck=1 (default, change to 0)
SHOW "DROPPED FRAMES COUNTER WHEN CAPTURING
FILE -> DVDMFCap.ini
[CAPTURE_SETTING] <section>
ShowCaptureInfo=0 (default, change to 1)
example: ShowCaptureInfo=1
AutoDropBitRate=1 (your choice)
ForceToUsePreviewMode=1
Always BACKUP files before editing them.
Another tip: Don't edit mpeg files.
Hope this helps,
MD
Some Tips:
[DMF_ENC] <section>
Hope this helps,
MD
maddrummer3301
JJordan
I confess I am an idiot - my verson is not SE if that makes a difference - but I have no "Advanced" tab on the page where you import the videomaddrummer3301 wrote:It you want all the chapters to show up on the main menu
plasma_video
Advanced Tab
I believe the tab mentioned can be found in the menu creation area, not in the capture area.
