Video Studio 9 keeps CRASHING
Ryan Lundy
I am getting extremely annoyed that after about a year of not using my VideoStudio 9 software it is now crashing constantly. I am trying to put a years worth of camcorder footage on the external hard drive and have given up after 6months worth. So now I am trying to edit and again the sofware will run for anywhere between 30-45 seconds. I installed a patch from the website and still no change. I have also tried working off my C: drive but again no difference - please please please help I have got some serious editing of my kids growing up to do for my Mum who lives in NZ!!
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
It could be something (software drivers etc) you have installed since you last used VideoStudio.
I suggest that you start be uninstalling VS 9 (click here for instructions and scroll down to Re-Installation of Video Studio 9 ) and then re-installing it.
John a
You may have some corrupt* video files. (Are these MPEG files?) Sometimes a "bad" file will play OK, but cause trouble when you try to edit or convert it.
This problem is most common with more-compresed files (i.e. MPEG-4).
But before I get ahead of myself, what format are your files?
What kind of camcorder do you have (MiniDV, hard drive, analog)?
And, how did capture the video to your hard drive (Direct firewire from camera, USB?, via an analog capture card)?
* I believe this corruption is usually do to software / codec issues (something wrong with the MPEG data-structure). It's usually not a hardware problem that would be caused by using an external hard drive, unless you are doing real-time capture to the external drive and it cant keep up with the data flow.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
VS Crashing
see if any of the following helps
Check out the following to optimise your PC and Video Studio to hopefully avoid most of the problems that sometimes happen when working on your projects.:-
Read this before posting …
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
Always follow the recommended procedures Go
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=18318
Delete unwanted and temporary files to help avoid possible conflicts,crashes
and free up space
It makes things a lot easier if your clips ,files and projects are stored in the Library Manager then they can be deleted in one swoop.To access the L.M either Go Tools –Lib Man or select it from the list via the drop down arrow next to where you change the library type.Choose the media type then new-name it,select edit to amend name/description if required.You can then delete the named folders and their contents in one go when you want to.
If you did not use the L.M. a project file will have a .vsp extention.
To delete non consequtive files - Select the 1st file then hold down control as you highlight each file then click delete +shift to delete them all.
To del consequtive files – Select 1st file, +select the last clip which will highlight all inbetween then press del. + shift which will remove all those clips from the library.In V.S. 9 + later confirm that you want the files deleted from the hard drive too.In V>S> 8 + earlier deleting and icon will also delete the original file whether image,audio or a video file.
Delete the contents of the Windows Prefetch folder (NOT the folder) Go
C:windows-prefetch
If you did not shift+click to del. in Windows –empty the recycle bin.
After making a DVD Go my documents-ulead folders + delete folders
named convert(only those in my docs)
In preferences-create disc select clear cache to del. converted temp files on
leaving Video Studio
Go
C:documents and settings-user name-local settings-temp to del. those temp files if you can see them, if not you may need to show hidden files.in XP Go
Tools-folder options-view-show hidden files and folders
You can also Go
Tools-preview files manager to del. temp preview used project files
Delete all unwanted files on your hard drive, it can slow down as it fills up.
In XP Go to My Computer-right click C: (or your hard drive) –Properties-Disc Clean up, this can sometimes catch files you may have missed and will delete them for you.
Use a dedicated hard drive for your capture or failing that partition your H.D.Use Ultra/66 7200 rpm drives or faster with as much capacity as you canWhen you capture to your C: drive and the system your PC has to read files from +to it at the same time and large avi files could cause problems
Defragment your hard drive often for more efficient operation,( there are many programmes that will do this better than windows can )
This tidies up fragmented files on your hard drive. Go
http://phpbb.ulead.com.tw/EN/viewtopic. ... =rendering
So, defrag after you have deleted all unwanted and temp files
Enable DMA (direct memory access.) for IDE discs capturing video.This moves info from system memory bypassing the CPU and helps to avoid dropped frames.In XP Go start-control panel-system-in system properties dialogue box-hardware-device manager,double click ata atapi controllers-
Choose ide channel-advanced settings-dma .
Disable write behind caching.In XP go
Control panel-system-hardware-device manager-double click disk drive-choose hard drive-double click policies.Set paging (swap File) size.Set min+max to twice your RAM (random access memory)
With write behind caching video is stored in your ram in the Ist instance and written to disc later.
Sometimes incorrect VS operation can be solved by Go add or remove programmes via control panel-select VideoStudio-change remove-repair.
Titles:- if you don not keep them in the safe area ( a box in the preview window) you will not see all of them on your TV screen ) Go file- pref-gen tab-display title safe area.
Apply anti flicker filter in pref create disc to improve viewing menu pages on a TV .
For best use of DV quick scan in DV to DVD Wizard (which scans a dv cam for scenes to import) and device control with a correct dv tape timecode:-
Record all of a blank tape without stopping with the lens cover on first. Recorded.scenes will be detected by date and time (as they will be under edit-split by scene).If you rewind to view a recorded scene on your cam, make sure you start recording exactly where you left off or the time code may zero again and may confuse VS or cause capture problems.
For inspiration view a sample project and practice on it.Go
C;\programmefiles\ulead systems\ulead video studio 9\samples\sample-pal vsp/sample-ntsc.vsp
Instant playback will let you view your project without a temp preview file being created but it will not be100% smooth depending on your PC spec as well.
Select non square pixel rendering to reduce distortion and maintain DV resolution when viewing on a TV.From the project properties dialogue box via project options and preferences select non sq pixel rendering .
Don’t forget those FAQs(frequently asked questions) Go
www.ulead.com/tech/faq.htm
Before you capture from your cam (powered by an AC adapter) close other progs that may be running like a screen saver or anti virus software that will take up processor resource.
Forum Search to a known number post.Select the address at the top-press left arrow key-get flashing cursor on the right of the previous number then backspace out the old number and enter the one you want to get to.
Make sure that you have the latest version of video card drivers.
If you need to reinstall Video Studio have a look at
http://phpbb.ulead.com.tw/EN/viewtopic. ... 5773#55773
Also view
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=17953
re selective start up
and
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=18782
re Date Execution Prevention and VS not loading properly.
And
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=13950
re Creating a Video Editing Profile to avoid programmes running in the background and speed up rendering
and free up space
C:windows-prefetch
Go
You can also Go
Also view
and
And
Ryan Lundy
Thank you guys for the advice and suggestions posted. Unfortunatley still no joy. I have been through the "Creating a Video Editing Profile" checklist/tutorial and still to no avail. I have uninstalled, defragged, changed and rechanged settings and this is getting beyond ridiculous. Any more suggestions - I have read through the FAQ's and someone had a similar problem but they seemed to get it sorted - was it because of upgrading?
Any suggestions really welcome!!!
There have been numerous options put forth, along with a few questions that you have not provided answers for. Such as one by DVDDoug
Please read this post, and return with as much of the information as possible.
I think with more details (Project Properties, Video File Properties, How you're capturing/transfering the video to your PC, the capture card being used) we can nail this down. You state that you've been through setting up Video Editing Profile, however did you set up a profile? Are the video files you are using, ones that have been setting on your system for the 6 months or did you start anew? As DVDDoug suggested they may be corrupt. Yes this can happen with files just sitting on your system.
.Are these MPEG files? But before I get ahead of myself, what format are your files?
railroadguy
This may have nothing what so ever to do with your problem but it is something to be aware of.
I use a menu program to create Java menus for Websites. Worked for a few months and one day it crashes on start up. Removed it and reinstalled, same thing.
I keep track of any new software I load, just in case there is ever a conflict, but nothing came to mind.
So, I start shutting down background jobs, one at a time. Finally I shut down Zone Alarm and bingo, the program worked. Restarted Zone and the famous blue screen of death!
Zone recently had an update and something that it uses conflicts with my menu program. This is not the first time as a Zone update a year or so age messed with Eudora which I use for Email. Zone patched that within a few days
You went a whole year of updates to programs and probably installing new ones. Something is conflicting with VS and it's going to hard to figure it out.
Have you tried the demo VS10 to see if that will work? Worth a shot.
