moviefactory 6 plus trial installation problem
rikrik
Post by rikrik »
hi guys, i just downloaded the trial of mf6 plus, tried installing, got some error message, so i re downloaded it, then a message said access denied?, then carried on to install......
the program crashes when i try to import a dvd file, i also bought ages ago number 4 then 5 of mf....they have stopped working aswell now....as in crashing when importing dvds.... :( :( :( :( :( :( :(
any ideas whats missing...
thanks.
Re: moviefactory 6 plus trial installation problem
rikrik wrote:hi guys, i just downloaded the trial of mf6 plus, tried installing, got some error message, so i re downloaded it, then a message said access denied?, then carried on to install......
thanks.
What's missing is the content of that error message - are we supposed to guess?
Please view
Re-Installation of Ulead Products
also
Basic Computer Troubleshooting Techniques
rikrik
Post by rikrik »
no your meant to guess, sorry it was this morning when i had the message, and i didnt know of this forum until many hours later....
i actually did uninstall it, cause i thought ive already got number 5, ill go back to that, then found that didnt work now at importing......
i can get to this screen, for importing dvds, but as soon as you just click on what you want to import, mf5 and 6 just crash now....:(
To begin with try the Windows system Restore to see if you can go back to before you tried to install MovieFactory 6+
rikrik
Post by rikrik »
i just tried that, but for some reason i can only go back to yesterday now, which is when i installed it......:(
and i just did the unistallation procedure, you put me on to , the re-installation of ulead products.....and re installed it.......
it still crashes as soon as i select a dvd import, it lets me import a wmv ok...just not the dvd vobs.....
Have you tried a few different DVDs to see if maybe you might have a bad disc? Try cleaning the DVD to remove any smudges, and fingerprints. Then it may be a problem with your drive itself, incompatible with the type of disk your are trying to import from. One thing that concerns me is that you have this problem with all DMF versions, which also leads me to believe it is a problem with your drive.
etech6355
Post by etech6355 »
I would also make sure the dvd isn't damaged. Try a known good dvd. If the dvd is good then
I would go to the \Program Files\Common Files\Ulead Systems\ and move or rename the complete "Ulead Systems" directory as a backup.
Re-install MF6 again (over itself) or perform a repair.
This way the program is using it's correct distribution files.
The error may have been a locked file running resident in memory under taskmanager.
If you can't re-install the MF6 trial because it's a trial then move or rename that directory I posted and re-install MF5.
I would do that to eliminate any conflicts, providing you think the dvd your trying to import isn't damaged.
If the above suggestions fail then try our troubleshooting hints
Troubleshooting your computer
rikrik
Post by rikrik »
ok guys, right ive tried importing a dvd folder, as i have some on the hard drive, it crashes when you click on what you want, the same with loads of dvds i tried...
i used to use mf5 nearly everyday before, it worked perfect...now thats the same....
when you get the import screen up, as soon as you click title or chapter, the black video screen to the left does a brief flash of white, then crashes....
i just hope i still have my mf5 installation files somewhere, as i got an download upgrade from number 4.....
rikrik
Post by rikrik »
thanks for the help guys, but i decided to uninstall mf6 again, and miracle of miracles mf5 works now, i can import again......which is strange cause when i uninstalled mf6 the first time, mf5 still didnt work.....
thanks anyway guys.....
i just get this message now when ive impoted a vob, is this something i need..
You can do a google search to try and find a download or you can use a similar font.
http://www.musicaecomputer.com/fonts/ca ... nglish.htm
