How To Edit & Convert AVCHD Files
joshua
Post by joshua »
I found this while looking for some knowledge... if you are interested in editing and converting the AVCHD files, this is for you...
Code: Select all
http://www.jakeludington.com/camcorder/20070118_how_to_edit_avchd_m2ts_files_from_sony_hdrsr1_camcorders.html
etech6355
Post by etech6355 »
Josh,
There are a few writeups from users of these cams.
Eventually they got there's working.
Quoted from po'duser:
THe other remaining issue is that you still cannot import .m2ts files which were previously taken off the camcorder using the Sony Software and stored on my computer. I am not sure what the difference is between m2t file (as found on the camcorder) and m2ts file (which is the format they are converted to when you transfer them to computer using the SOny software), but it seems to make a big difference to MF6. I would strongly recommend you do not us the Sony software to import files from the camera as this is when the conversion to m2ts occurs. You can simply copy the m2t files from the avchd directory of you camcorder by simply browsing to it once it is connected. It should show up as a removable drive.
Also you can read these 2 threads, should be helpful:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=21182
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=21187
This ones long but the outcome is good:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=20965
joshua
Post by joshua »
Thanks for the info etech6355, much appreciated
