Like Corel Draw and Photoshop, anyone know if Ulead PE has specific requirement for setup RAM memory management, and Virtual Memory management? In Corel Draw normally I choose a diferent partition to it use for his temporary files and its own virtual memory usage. But in PE I am not getting find something about.
Thanks for help.
Photo Express 6 - RAM Memory Management and Virtual Mem Mngt
htchien
Welcome to the forum.
In Ulead PhotoImpact you could select File->Preferences->System to set the memory management for virtual memory / RAM / hard disk. If you could find similar settings in PE then you should be able to set it also. If you could not find it, well I think maybe Ulead think you do not have to.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
Thanks !
Thanks,
I will try to check this accordingly. Although I am in view to change to PE 6, and maybe use PhotoImpact too, always am I am trying the best in memory and files management.
Jorge
Jorge
Hi Ted
Hi Ted,
I resolved to post a small words here to say hello and to see if can help with some ideia regarding other problem which a friend of mine has with her PE 4, in case if can give us a time in read there. I posted a long text in other msg today.
Jorge
Jorge
htchien
Sorry I'm late to see this post.
I've not used PE for a very long time, sorry if I could not help you on that....
Ted (H.T.)
