Compression configuration
paulinho
Post by paulinho »
The total time of my file is of 1:08 minutes, being movie more pictures.
Would be which the correct values what I should put in the option "Compression", for me to obtain an exelente image and sound?
Tkanks
Paulinho
Post by Trevor Andrew »
Hi Paulinho
When you select Share / Create Video File / NTS DVD” you are using one of video studios templates.
All the settings should be correct for a one hour video.
The ‘create video file window’ has a ‘properties box’ that you can scroll through to view the settings.
I am in England therefore Pal, but your settings should be similar to.
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
LPCM Audio, 48 KHz, Stereo
The bit rate of 8000kb/s is suitable for a one hour movie.
Your 68 minutes of video should just fit, but is getting near the limit.
If you want to be sure use the custom option keeping the same settings as above with the exception of the bit rate.
Reduce the bit rate to 7000 kb/s.
Hope this Helps
Trevor
