I am so frustrated right now. I have been working on creating a DVD for school for 5 days. I videotaped a performance, and am trying to burn it to a DVD.
There seems to be some sort of glitch between the program preview and what actually burns. I can see the preview, and everthing looks great & works great. Then, I burn the DVD and try to play it in my DVD player hooked up to my TV. And it doesn't play everything. It skips chapters - they appear on the menu screen but I cannot click on them to access anything. Or it will delete a portion of a chapter, just stop. Sometimes it will freeze in the middle of a chapter.
I thought the problem might be memory & size. So, I got rid of the motion menu - just stills. With motion menu, it would take 2-4 hours to burn a DVD. With just the stills, it takes 20 minutes.
I have deleted the movie, and recreated it from scratch (3) times so far. Each time, the same problems reoccur but in different places.
I have deleted the program and reinstalled it. The problems still exist.
I have an HP with LightScribe
1g RAM
250g hd
Movie I am trying to burn has 16 chapters, and is 3.06g in total burning length.
I am ready for a refund at this point, unless you have some words of wisdom. I bought this after weeks of searching for something easy to use, after a demo trial, and am very very very frustrated. It's a great product, the end result has the potential to be wonderful - I just can't seem to get it to burn correctly.
DVD MovieFactory+ doesn't burn what is shown in preview
rbh5,
Could you describe your source video, it's 3gigs, that's all we know about it.
How did you create/obtain the source video? What is it's format?
If you right-click on the source video and select "Media Properties" the video/audio properties of the video will be displayed.
Post them back to this thread and explain how you created / obtained the source video.
Your problems are usually related to the source video having corruption in it.
Especially not being able to seek to the correct chapter is an indication.
There are programs that can repair a corrupted video file.
You might have a compatability problem between the DVD and the DVD player.
Does the finished DVD play on the computer? (If not, I'm on the wrong track here, and Movie Factory is having trouble converting your files to DVD-compatible MPEG-2.... In that case we will need to know more about the source files you are working with, as etech said.)
Have you ever played a "burned" DVD on that player?
Have you tried it on another DVD player?
Some DVD players can't play burned DVDs at all. Others can play DVD-R, but not DVD+R, and vice-versa. Some can't play R/W discs, etc. In general, your best odds are with DVD-R.
A couple of other tricks to make your disc more playable:
Burn at a a slow burn speed (4X or less)
Keep the bitrate below about 7000kbps.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
rbh5
I figured it out
I have a minidv camcorder, Sony brand new. I was taking the minidv and importing the video from that. The importing of video went fine. I was able to create chapters, separating each child's performance for easier finding for parents. That worked great. I would go to preview what I had created, and everything would work fine.
Then, the hp would burn the video to DVD and all heck would happen. Chapters would have no video attached to them. And it would always be the same chapters that had problems.
The created DVD would play in both of my players, one is older and one is new (one Panasonic & one Sony). All of the chapters would appear in the menu, but you couldn't click the chapter to view the attached video. It was as tho there was no attached video.
So, I once again walked away from this... had some Ben & Jerry's while watching TV. And decided to once more - remove the motion part of the menu - delete only the chapters that were affected & the prior/after chapters - and try once again.
BUT, this time I unchecked "create chapter menu" and checked "add title menu." Saved the video with the deleted chapters. Closed out of the program completely. Restarted the program, opened the video. Recreated the chapters, checked "create chapter menu," unchecked "add title menu" - and it worked fine.
It is as tho the program saves those original chapters and will not rewrite them if you make any changes. I do not like that feature. I would like to be able to make changes in chapters, and burn the new video with the changes intact.
I do like the simplicity of this program, and the way it will enhance a darker video (this one was taken in a school caf in dim lighting). I find the "help" to be very unhelpful. I love this forum for all sorts of answers.
thanks,
Robin
thanks,
Robin
Could be that "Ben & Jerrys" is a requirement, at least a good excuse if any to make a workable dvd
Question:
In the capturing module, there is a Format Box. Did you capture directly to MPEG or AVI.
The format box defines the file type captured. Type AVI would be a Dv.avi file which is a copy of the dv tape (what's on the tape).
MPEG is a mode where the dv video from the tape is converted "On the Fly" to the mpeg format. It's much faster to capture in the mpeg format but can cause problems because a fast computer is required.
One of the best procedures to use in MF (any version) is to capture with the Format Box set to "AVI (dv.avi)". Then after capturing you return to the timeline, save the project. If you want to edit the video then do any editing. While still on the timeline after your done editing go to EXPORT and select "Fast Export Dvd Compliant". This will create a mpeg2 dvd compliant video file on your harddisk that have the same properties as your "Project Settings". You should set your "Project Settings" and "Working Folder" when you first start any video projects. Also under "Preferences" make sure "Quality" is set to BEST.
After you create the mpeg2 file, start a new project and use that new mpeg2 file for your project to mark chapters, create menus's and burn the dvd. The mpeg2 file is the actual video written on the dvd. That's the dvd format, mpeg2 video. The mpeg2 file is also on your harddisk and can be re-used to create new dvd's in any video program.
So if you plan to use the enhance video or edit the video I would recommend capturing to dv.avi (large files), perform editing and export/create a compliant mpeg2 dvd compliant file. Use that mpeg2 viideo file for new projects etc. You can also play the mpeg2 video using any software player on the computer.
Converting the captured dv.avi file to mpeg2 does take longer but is to me a more reliable method. You can also adjust the quality of the video by customizing your video-bit-rates under "Project Settings" (GEAR Icon) "Change Mpeg Settings -> Customize".
In this customize module with the settings it's important dv tape conversions to set your "Fielding" to "Lower Field First", this is very important for smooth video conversions.
DV tape uses "Lower Field First", so make sure if converting to mpeg2 file your settings are also "Lower Field First".
Also another procedure for checking and testing your dvd is in the burning module click on the down arrow to display additional options. Uncheck to burn a dvd and check ON "Create Dvd Folders". Point the creation for a dvd folder on your hardisk in a easy location for future access, such as C:\School_1
The program will then build a dvd on your harddisk, this is a mirror of what would be burnt onto the dvd.
Then you exit MF6, launch either Power_dvd or windvd and in the software player select playback from harddisk or play dvd folder, wording similar to this. The program will then play your dvd from the harddisk and you can test it to see if the menus are correct, check spelling, audio levels etc.
After you check the playback and it's correct you can burn a video-dvd using MF6 from the launcher menu. In one of the features from the launcher menu you select burn dvd folder.
Your corrupted menus and chapter problem would have shown up using this method, saving you the time of burning a dvd that didn't work.
Question:
