Video Studio 8 SE help
thirudi93
Post by thirudi93 »
hi
i have make a video with videostudio and i want to create a dvd
but i burn the dvd there is the conversion of video
and during the conversion there is a problem
and i must close the program
some one can help me pls
randazzojp
Post by randazzojp »
What kind of problem? What's your configuration etc.
We certainly need more information. But I suspect you are in much the same boat as another person I just answered on this forum.
Once you had edited and previewed your project, I am assuming that when you say you 'make a video' that you went to Share > Create Video File > DVD. But can you confirm that please, and also tell us exactly what properties you selected for the new file.
If you are burning a DVD from the video you made and it is converting during the burning process, that is a clear indication that the properties you in fact used were not DVD-compatible. That is why we need to know the exact properties of the video you made.
thirudi93
Post by thirudi93 »
Thanks for answering
I went to Share > Create Video File > DVD
The file is MPEG
But before i had burn a dvd with this program.
My english is not good lol sorry for it
Post by Black Lab »
Read this post: http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959.
Maybe that will better explain what kind of information we need to help you.
thirudi93
Post by thirudi93 »
Nature of the problem: i have already explain
Properties of your source files (format, file size, where did you get it?) : All files was in MPEG, size: around 1gb, i was filmed with my video camera
What devices are involved and their mode of connection?
Project Settings : juts including picture with the video, music
Output format (file, DVD, VCD, SVCD) : DVD
PAL or NTSC : pal
Error Codes (if any)
i have a windows where there is write : this program must be closed because windows had detected a problem
send this problem to microsoft support
don't send
it is like that the windows
Ok so we now know that you captured MPEG (MPEG-2, MPEG-1, or MPEG-4)? That you captured from your camera (camcorder or digital still)?
IF you captured from a camcorder to MPEG-2 (DVD compliant) then your Project Properties should match as closely as possible to that of your video file. Maintain that through out your process, including when you are going to burn a disc, or create folders (Video_TS) on your PC. If you captured video is from a digital source (DV) and via Firewire (IEEE-1394, Sony's iLink) then the Field Order should be Lower Field First. If it is from an analog source (for example a video capture card), then the Field Order should be Upper Field First.
Now IF your video came from a Digital Still Camera then the above does not apply.
Please advise what type of camera (camcorder or still), and the Make/Model of the camera, and how you got the video into your PC...
thirudi93
Post by thirudi93 »
My camera is sony handycam
with dvd
so after i insert the dvd in my PC and with video studio i got the video in my pc
Ken Berry wrote:If you are burning a DVD from the video you made and it is converting during the burning process, that is a clear indication that the properties you in fact used were not DVD-compatible. That is why we need to know the exact properties of the video you made.
We could use this answer to help further.. To find out what the properties of the video files are: Right-click on the video in the time-line of VS, select Properties. Copy them down and post them back here please.
Also go to File>Project Properties or keyboard shortcut ALT + Enter, copy those down and post them back too.
One more place for properties, which is separate from the Editing Module, would be the Burn Module (Share>Create Disc). Click on the Gear-Looking icon located to the lower left, and post those properties also..
thirudi93
Post by thirudi93 »
PAL (25 ips)
Fichiers MPEG
24 Bits, 720 x 576, 25 ips
Champ inferieur d'abord
(DVD-PAL), 4:3
Taux de donnees video : 6000 kbps
Audio LPCM, 48 KHz, Stereo
roy wood
Post by roy wood »
Hi 'Vidoman asked you for:-
(a) Your film clip properties.
(b) Your VS 'Poject Properties'.
(c) Your DVD Burn Properties.
One more place for properties, which is separate from the Editing Module, would be the Burn Module go to(Share>Create Disc). Click on the Gear-Looking icon located to the lower left, and post those properties also..
I hope you now see there are 3 settings that we need to compare.
Please list them as (a) + (b) + (c).
[/quote]
Feedback after members have endeavoured to help you is not only good manners it also helps others to know if a given solution was effective. Thanks.
flguy
NEED help getting serial number
Post by flguy »
How can I get the serial number for my video studio 8 se dvd
bill
