DVD Moviefactory 6
SMeyer
DVD Moviefactory 6
Post by SMeyer »
I have downloaded the try version. But have problems when I try import from a DVD-disc. When I press Import-button the program shows me a list over titles on the disc. When I click on a title, the program stop showing me an error-message: "un exception 'unhandled Win32Exception' has occurred in DVDMF.dat.
I have tryed on 2 different computers, I use a DVD disc I have made myself - I mean without any copyrights-keys.
DVDDoug
Moderator
Post by DVDDoug »
I you made the DVD with a stand-alone recorder, or with a DVD-camera. make sure you've "closed" or "finalized' the Disc. (You would need to do that with the disc in the original recorder/camera.)
Ulead does seem to have trouble with DVD's from some sources. So if the above suggestion doesn't help, you can try using VOB 2 MPG (Free!!!) to create an MPEG file.
There is also a free program called FixVTS, that might be able to fix-up your DVD's structure so it can be imported. (You will have to copy the DVD to your hard drive first.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
