Problem with VisualStudio 10
ccla
Post by ccla »
Hello,
I've jsut started using VisualStudio 10 SP1, and I am running in a few problems. The first time I tried to burn a DVD the program faulted and created the following log:
Faulting application vstudio.exe, version 10.0.0.0, faulting module mpegin.dll, version 1.1.1.168, fault address 0x0005d8cc.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 76 73 74 ure vst
0018: 75 64 69 6f 2e 65 78 65 udio.exe
0020: 20 31 30 2e 30 2e 30 2e 10.0.0.
0028: 30 20 69 6e 20 6d 70 65 0 in mpe
0030: 67 69 6e 2e 64 6c 6c 20 gin.dll
0038: 31 2e 31 2e 31 2e 31 36 1.1.1.16
0040: 38 20 61 74 20 6f 66 66 8 at off
0048: 73 65 74 20 30 30 30 35 set 0005
0050: 64 38 63 63 0d 0a d8cc..
So I rebooted the computer to try again, but now everytime I start VideoStudio I get a fault and the following log entry is created:
The application, C:\Program Files\Ulead Systems\Ulead VideoStudio 10\vstudio.exe, generated an application error The error occurred on 03/12/2007 @ 21:11:47.250 The exception generated was 80000007 at address 00000000 (ntdll!KiFastSystemCallRet)
I am not including the data on this last log because it is too long.
Basically I now cannot use the program anymore.
Does anybody have any ideas?
Claudio
ccla
Post by ccla »
Thank you Steve. I will give it a shot tonight.
Claudio
ccla
Post by ccla »
I followed the instructions to uninstall and then re-installed with no luck. The programs crashes at the same point in the rendering.
Any other ideas?
Claudio
ccla
Post by ccla »
By the way I have other ULEAD products installed (the bonus CD with VideoStudio 10, and PhotoImpact 12).
Should I uninstall every program?
Claudio
Post by Black Lab »
ccla wrote:I followed the instructions to uninstall and then re-installed with no luck. The programs crashes at the same point in the rendering.
Any other ideas?
That sounds like you could have a bad clip. Have you ever been able to render without it crashing, or is this your first attempt?
ccla
Post by ccla »
Thanks,
I did not even think of it. I did use the same clip to burn the DVD so maybe that is the problem. I will try a different one tonight.
Claudio
ccla
Post by ccla »
Nope, that was not the problem. I tried with other clips with the same result.
Claudio
Possibly you have a conflict. Try Creating a Video Editing Profile
If that does not work then please view:
Basic Computer Troubleshooting Techniques
ccla
Post by ccla »
sjj1805 wrote:Possibly you have a conflict. Try Creating a Video Editing Profile
Sorry it took so long, but here is what I did. I purchased a separate HD for my laptop (a 60GB Seagate SATA) and installed Windows XP with SP2. I then installed PhotoImpact 12 and VideoStudio 10 Plus (with all of the additional programs included such as WinDVD, Cool 3D, and so on). I was able to burn one DVD. After that the same problem started appearing again. I then followed the instructions on creating a Video Editing profile. No luck, I still cannot create a DVD. What else can I do?
Claudio
ccla
Post by ccla »
Apparently it was my burner that was causing the problem. I purchased an external Burner and now I can create the DVDs.
Claudio
