NEWBIE TO DVD WORKSHOP NEEDS HELP
MRDVideo
I'm new to DVDWS but an older dog with respect to video editing. I have finished a project using CANOPUS EDIUS video editing software. I also use CANOPUS PROCODER EXPRESS to encode the video in preparation for DVD burning. But before I burn the dvd I want to author the dvd with DVDWS so that I can have a menu. Specifically, I cannot figure out how I use the output file from PROCODER EXPRESS as input to DVDWS. Also, when editing the video with EDIUS, I made use of markers to set chapter points. Will these chapter points be recognized by DVDWS?
I don't have Workshop installed on this machine, so I won't try to give you the exact details...
Go to the Edit Window. Open your MPEG file and drag it into the time-line (below the preview window).
You won't be able to import the chapter-points, but it shouldn't be to hard to re-create them if you know the starting-time for each. (There is one slightly tricky thing... Navigate to the chapter-point before you click Add Chapter. (The Add Chapter button will be grayed-out until you advance the program.)
In the Edit-Video window, there is a check-box that says Convert To Disc Template. Since you want to keep the Canopus encoded MPEG, Uncheck that box, and the video will not be re-coded. There is a similar check-box in the Edit-Audio window, if you want to keep the audio encoding.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8962
http://ftp.ulead.com/pub/Manual/worksho ... manual.zip
