Hi -
I was applying video filters (auto levels and noise) to a single clip, and after crunching awhile it finished but wouldn't play the preview. Instead, VS10+ popped up this error message:
"Multiple File Playback error. Cannot play. Make sure Direct Show and your sound card are installed correctly."
I have had no trouble playing back a wide range of projects, and I can still play back the underlying clip I was experimenting with (after I selected "clip" instead of "project" so I was no longer attempting to look at the rendered preview.)
Any thoughts as to what causes this error and how I can cure it? These video filters are powerful and I want to be able to user them.
Thanks,
David
Error msg: "Multiple file playback error. Cannot play.&
brodwidr
- motherboard: Dell MoBo 0M3918
- processor: Intel Pentium 4 3.00 GHz
- ram: 1.5 GB
- Video Card: NVIDIA Quadro PCI-E Series
- sound_card: built-in
- Hard_Drive_Capacity: 75 GB
VS 10+, windows XP pro SP2, Dell Dimension 4700 P4 3.0 GHz, 1.5 GB RAM, 40GB and 250GB SATA HD, Nvidia Quadro Duo.
Hi David,
I've also had that error pop up on occasion when rendering a preview using the High-Quality Playback setting. I don't have any idea what causes it. I've done a google search on the error, and the only entries apply to older versions of MSP.
One article on the Creative Cow Forums suggest a problem with the Matrox MPEG codec. Adding some lines to an ini file was recommended by Ulead tech support. However did not seem to produce a cure.
brodwidr
- ram: 1.5 GB
thanks
Thanks, Ron -
I'll get in touch with tech support.
- David
- David
