Error installing windvd
Moderator: lata
petedran
Post by petedran »
I downloaded version 8 of windvd and started to install. during the install process a window opened up titled "WinDVD errors" "Error 1904.Module C:\Program Files\Intervideo\Common\Bin\Sharpness.dll failed to register. HRESULT -2147220473. Contact your support person.
I hit ok and hit it about 10 more times before it continued with the installation. It seemed to work ok but when I try to run the program I get a windows error and cannot run windvd. I previously had windvd v4 installed and it worked fine. I uninstalled the both versions of windvd and tried again with the same result.
Help. any suggestions. i am running winxp and the updates are current.
htchien
operating_system: Mac
Post by htchien »
Some components are not been installed properly, since you get the error while you install it.
You could contact InterVideo Tech Support to see if they would help.
http://www.intervideo.com/jsp/Support.jsp
Hope this helps.
H.T.
Ted (H.T.)
