My hardware:
1. Ibm Thinkpad (Lenovo) T60p 1.8 core duo 2 gb ram , ati firegl WINXP SP2
2. Self build Duo Core 2 3ghz 2 gb ram , Nvidia 7800 WINXP SP2
I hope someone can help me
Thomas,Norway
This is usually a codec issue.sjj1805: The error comes way before its actully get to the burning phase, its right away in the rendering phase
This IS NOT a codec issue, becuase i've tried al kinds of different formats to make sure , with the same result each time .. !etech6355 wrote:This is usually a codec issue.sjj1805: The error comes way before its actully get to the burning phase, its right away in the rendering phase
What are the video/audio properties of your source video, where or how did you obtain the source video.
From the timeline if you right click on the video and select "Media Properties" post the video & audio properties of the media that your trying to convert back to this thread.
I've tried it with XP SP2 on Core duo 1&2 with negative result. On AMD 3700+ it worked fine ..rasta wrote:mmm glad to find this, mf6 works fine in my fx x2 with vista at work, yesterday I tried in my c2d at home with xp sp1, and it pop up with this result every time it tries to start encoding:
UNSPECIFIED ERROR bla, bla..
it could be either:
1- core 2 duo related
2-needs xp sp2 or vista
3-?????
rasta wrote:So core 2 duo is the problem then! and I always thaught Ulead was Intel biasedI've tried it with XP SP2 on Core duo 1&2 with negative result. On AMD 3700+ it worked fine ..
