The program did not recognize my camcorder but I was still able to move the video from my camcorder into my computer using the camcorder settings. I was able to cut out some scenes (which I can do the same thing directly on the camcorder) but when I did the playback, it was very choppy and my sound was replaced with some music which I didn't choose. The other disappointing part of this project was that the video was not saved in HD format. It ended up as MPEG2.
Have you read the manual on how MF works. In ALL video editing software programs the first thing you have to do is setup the "Project" and "Project Settings". Please read the manual because this version of MF has many features.
First and most important, did you start a HighDefintion Project? If MF made a dvd then you must have had the settings to create a dvd.
IF MF6 let you import the videos from your camcorder into the Timeline and you can see them on the timeline then that's correct and great. The next step is after they are on the timeline to set your "Project Properties" to the same equal properties as the H264 Codec except in Mpeg2 format.
You set you
Project Properties under the "GEAR" Icon -> Change Mpeg Settings. Take specific notice to the properties of your AVCHD imported file on the timeline. You cam records in various quality settings, this is important to retain those video_bit_rate settings and correct fielding for proper HD Conversion.
Please give me some time because MF6 is new and I haven't had alot of time to work with it, but I've taken footage from dvd-rw's written in the AVCHD mode. Imported them into MF6, exported them and play them without issues on a PS3 unit, computer software & the linkplayer2 HighDef Player.
I've been able to copy our video's to a large DVD disc and can play them in the Sony Playstation 3. Unfortunately, Playstation will not play the small DVD discs which the camera uses.
Have you tried this. on my PS3 the mini-dvd is displayed as an AVCHD disk and plays no problem.I recorded directly onto a mini-dvd-rw disk, then finalized it, popped it into the PS3 and it played.
Have you upgraded the firmware version to the latest version on the PS3?
It should be Firmware Version 1.54
I haven't seen any software yet to date that can directly EDIT in the AVCHD format. The video(avchd) is converted to another format first that is in an editable format.
If you can import and display the videos on the timeline of MF6 then I can help you to get them to playback on the PS3.
The important issue is to get them into the timeline of MF6. That's been the key, to decode the codec, it's format and the transport container that sony/panasonic has developed.
It would help if you posted what HD files you did get to playback on the PS3 and how you did that. I don't have the software that comes with the cams to work with. I do know you have to change the cams settings to "Computer" or something like like so it's displayed as a device (or drive) in windows.
When your playing the videos back on the PS3 hit the "Start" button to display the properties of the video. That will tell give you information about the codec video/audio properties along with the bit-rates the video(s) were recorded at. You should also be able to copy them to the PS3 harddisk by highlighting the video, pressing the "Triangle" key and select "Copy".
In MF6 you right-click on the video after it's imported into the timeline and select "Media Properties".
etech
