I created a very good slideshow with this program but found out it would only allow me to insert 99 slides and I could not find anything like preferences or setting which might allow me to increse that number.
The program is about the best I've used and it is simple.
Any info would be appreciated.
dennisgbeau
ULEAD DVD Movie Factory 3SE
Probably because your using the SE (Special Edition) version. It can't have the patches for MF3 installed because it's a special edition. Usually distributed along with a piece of hardware.
A workaround for you version is after you create a slideshow of about 90 pictures and return back to the timeline. Then click on the create slideshow icon again to create the next slideshow (another 90 or so pictures).
After you create a few slideshows this way from the timeline if you click on the GEAR Icon the pop-up screen has a choice on how to play the DVD.
Select "Play Next Clip", that should be the default. You don't want "Return to Main Menu".
When you play the dvd back on a player all the slideshows will then play one after another.
