I right-clicked each from the Library and both look the same - I got the following for both:trevor andrew wrote: What are the properties of the original captured video file?
And the properties of the rendered file? They should be identical, but what are they?
File
File Format: Microsoft AVI files --OpenDML
Frame rate: 25.000 frames/sec
Date rate: 3515.63 kbps
Video
Compression: DV Video Encoder -- type 1
Attributes: 24 bits, 720 x 576, 16:9
Audio
Compression: DV Audio -- PAL
Attributes: 32.000 kHz, 12 bit, Stereo
The other weird thing is that if I play the saved AVI in VS10 from the Library it plays fine.
