VS10+ - Chapter entry frame numbers exceeding total frames?
KugarWeb
Post by KugarWeb »
Nature of the problem
When trying to create a DVD ISO image in VS10+ I have recently been coming up with the error "Some chapter entry frame numbers exceed the total frames". I have created this ISO using this project file lots of times now and since removing the effects to the exit and entry menu animations, and removing the menu altogether, I have come up with the error. However, when searching the forums and on Google, this only seems to be associated with MovieFactory?? :?
Properties of your source files (format, file size, where did you get it?)
Format: MPEG-2 Upper Field First
Total frames: 5,445.
Attributes: 24 bits,1440 x 1080 16:9.
Filesize: Anything from 20MB to 600MB per clip
Source: Sony HDR-HC1E PAL
What devices are involved and their mode of connection?
Connection: 1394 Firewire.
Project Settings
PAL (25 fps)
MPEG files
24 bits, 720 x 576, 25 fps
Frame-based
(MPEG-2), 16:9
Video data rate: Variable (Max. 6000 kbps)
Audio data rate: 256 kbps
MPEG audio layer 2, 44.1 KHz, Stereo
Output format (file, DVD, VCD, SVCD)
DVD ISO file.
PAL or NTSC
PAL
Error Codes (if any)
533:-2147216477:0
[b]Computer:[/b] Windows Media Edition, P4 3.0Ghz Processor, 2.5GB RAM, USB 2, Composite, FireWire 1394, SVideo, External HDD 150GB, External HDD 2 - 500GB, Internal HDD 250GB, Ati Radeon X600 256MB Graphics.
[b]Cameras:[/b] Sony HDR-HC1, Sony DCR-HC85E
Post by BrianCee »
This error is usually shown if you have changed the length (by editing etc.) of any of the chapters after creating the DVD menu - It can usually be overcome by deleting chapter points and then re-creating them
