Trouble importing DVD chapters
MPH711
- Hard_Drive_Capacity: 750
I have a DVD with music videos on it (not protected). Ever since I upgraded to VideoStudio 10 Plus I seem to be having problems. When I go to import something from the disc and screen comes on to "Import" or "Import Folder". After I select one it reads the disc (about 15 seconds) then as always comes up with a preview area that shows the chapters. This is where you can click on a box to select a chapter & then preview that you picked the right chapter and then import it. However, when I click on a chapter that I would like to import (and preview) I get the "hourglass" on my computer like it is reading it...but it never changes (I gave it 10 minutes...it's a 2 minute chapter it's reading) from there and I need to force a quit to get out of it.
I have used this import feature many times but never really had a problem before 10 Plus. Any suggestions?
Adrian Perkins
Just copy the DVD folder from the DVD to your HD. Then from VS, use the same Import function, but you'll be importing from the folder on your HD instead of the folder on the DVD.
Jeff
Dentler's Dog Training, LLC
If you have VS9, you can try it, but I'd guess it has something to do with this particular DVD....but never really had a problem before 10 Plus.
You can also try VOB 2 MPG (Free!!!).
Another tool you can try is VTSfix (Free!!!).
You can also try directly opening the VOB file with Video Studio. (You might need to copy it to your hard drive and rename it to .MPG.) Since it's a very short program, it's probably contained on a single VOB file. That should give you better odds with this "old trick".
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
- ram: 2 GB
- sound_card: Intel GMA 950
This sounds like the same problem I had and I have just posted a fix here:
http://phpbb.ulead.com.tw/EN/viewtopic. ... 808#108808
- ram: 2 GB
Sorry I inserted the wrong link, the correct one is here:
http://www.mediamax.com/sjj1805/Links/BD81604679
Also depending on how the dvd was created it may be impossible.
Many dvd's that have been re-encoded using dvd shrink or nero recode alter the mpeg2 file so it's playble but not editable anymore.
Something to consider when your project is over 4gigs and you use dvd shrink or nero recode to fit the video onto a single layered dvd. They are hard to import & edit after these programs finish re-encoding them.
MPH711
I did not find a file like that on my computer. I went ahead and downloaded the file and put it where you said to...then I tried to import a DVD again. The same thing as before happens.
Mike
(I have a DVD with music videos on it (not protected). Ever since I upgraded to VideoStudio 10 Plus I seem to be having problems. When I go to import something from the disc and screen comes on to "Import" or "Import Folder". After I select one it reads the disc (about 15 seconds) then as always comes up with a preview area that shows the chapters. This is where you can click on a box to select a chapter & then preview that you picked the right chapter and then import it. However, when I click on a chapter that I would like to import (and preview) I get the "hourglass" on my computer like it is reading it...but it never changes (I gave it 10 minutes...it's a 2 minute chapter it's reading) from there and I need to force a quit to get out of it. )
Mike
Adrian Perkins
