tecstar wrote:Where DVDA4 Studio wins (and this might be the critical difference for some), is the ability to manually control menu setup/navigation..
Ahhh! The critical difference for me! Including WS menus without having tweak it, and at under 30GBP ($50) it can be replaced in the future without losing too much. (130GBP for the Full DVDWS2 is a big outlay in comparison)
Yes, MovieFactory 6 (and some earlier versions of MF) has 16:9 menus as well (without needing to do any tweaks). It appears DVDA4S could be a good fit for your needs (i.e. you don't need any High-Def DVD Authoring or AVCHD support, and you don't need any of the other features and complementary software that Ulead provides in the MF6 Plus version).
If you do go with DVD Architect Studio 4, be aware that current versions of DVD Architect have an embedded "navigation" error that prevent discs from playing in some DVD Recorder/Player units (Note: the recently released 4b Patch for the
FULL version of DVDA 4 addresses this issue, but I don't think Sony has released an equivalent patch for their Architect
Studio version). I believe the error is due to incorrect "Start-bytes" for the addresses of several items in the DVD's IFO's. To manually fix it, you can open up an authored DVD in PGCedit -- a popup message will ask you to resolve some "invalid stream references...", and by checking OK, it should fix the navigation/start-byte problems...
George
