Do Not Convert Compliant Mpeg File is definitely checked.Black Lab wrote:If you have a DVD compatible mpeg, and you have Do Not Convert Compliant Mpeg File checked, it should not re-encode your file.
Here's the information for the files I am using:
MPEG files
24 Bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
LPCM Audio, 48000 Hz, Stereo
*EDIT* - Another program says this:
Video: MPEG2 Video, 720x480, 29.97 fps, 8579 kpbs
Audio: Dolby AC3, 48000 Hz, 2 ch, 256 kbps
This was from AVS Video ReMaker 2.2
Whenever I go to Video Studio Editor, and go to Share, then Create Disc, and add my videos, it says:
"File contains Dolby Digital audio tracks. DVD MovieFactory does not support this audio format. Do you still want to insert this video clip?"
Also, the audio DOES play in AVS Video ReMaker 2.2. I have the trial version, and it won't do full-length stuff like I need.
