you`d think this would be easy with all these tools at my disposal. No i cannot
create a bent tubular steel object, half hula hoop shape! can You?
bent tube 1/2 hulahoop object creation query
- VikingAnimations
- processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
- ram: 4 GB
- Hard_Drive_Capacity: 1 TB
- Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Add a cylinder object... Change the object's dimensions to your liking in the Attribute Panel under "Geometric Objects." In my little test, I used Top Radius 2, Bottom Radius 2, height 100.
Apply the Bend effect #3. Delete the key frame for the last frame. Go back to the first frame, and change the Bend attributes thus:
Level: 25
Cutting Point can be left at 50, and direction as x-z, symmetric.
You will now have half a hula hoop.
You will, of course, have to tweak things to get it the size you want, etc.
Hope this helps!
Level: 25
Hope this helps!
shaun
- VikingAnimations
- ram: 4 GB
