I am capturing video from a dv camcorder with a fire wire connection. I capture to DV-AVI and will be doing alot of editing and transitions and will eventually output to DVD. My project properties are:
NTSC 29.97
Microsoft AVI Files
24 Bits, 720X480, 29.97
Lower Field First
DV Video Encoder-Type 1
DV Audio-NTSC, 48.000 KHZ, 16 Bit, Stereo
Yes, I will edit with the exact same properties. My question is... I know that when I burn to DVD that I will change to Mpeg2 in my file format setting for encoding. BUT... WHEN I CREATE MY VIDEO FILE...Should I keep the settings the same as above and still render it as a AVI File, or should I change it to Mpeg files at this time? Also do the rest of these seetings sound accurate?Thanks to everyone in advance
