help please
how do u enable extra template options??
nikkio3000
hi i heard it's a way to enable a load of extra dvd workshop template options by tweaking a file that dvd workshop uses, it a file somewhere that you edit in wordpad ot somethin.
help please
help please
- ram: 2 GB
- sound_card: Intel GMA 950
C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead DVD Workshop\2.0\DVDWS.ini
Now add the following under the heading
[VIODRIVER]
Advance=1
Disclaimer by Ulead:
This is not an official solution by Ulead. This involves editing a critical program file and any other changes to it can cause the program not to run properly. If you encounter problems with the software and ask for Technical support, the TS guys may not be able to give the exact solution because the program has been tampered. Tech Support can never know for sure what other values are changed so its better to be safe. Its like voiding the warranty of a certain electrical device by removing a jumper or modifying its circuit. Make sure you backup those files and revert it to the original one and then ask for TS assistance.
It is covered in the EULA under "2. Use of Software: You may not: 4) reverse engineer, decompile, or disassemble or otherwise attempt to discover the source code of the software"
I therefore suggest you make a back up copy first so that you can always revert to the original.
[VIODRIVER]
Advance=1
- ram: 2 GB
My advice to most users is to leave the tweak alone.
If you were supposed to have access to these options they would have been enabled by Ulead (Now interVideo*Ulead / Corel)
The extra options allow you to tinker with various settings such as the number of i-frames
de-interlacing,
VBV Buffer Size
Progressive Sequence
Progressive Frame
Intra DC Precision
and several other things meaningless to "Mr Average."
de-interlacing,
VBV Buffer Size
Progressive Frame
Intra DC Precision
